Brakes and Scales
Discussion in 'Experienced Truckers' Advice' started by motocross25, Jun 9, 2017.
  1. motocross25
    motocross25 Road Train Member
    3,805
    11,487
    Sep 23, 2010
    Overland Park, KS
    I recently scaled a load at a major truck stop chain, and whilst looking at axle weights all over the place, a fellow driver must have noticed my puzzled look and offered up this piece of advice. He said while on a scale, not to set the brakes. Rather, while leaning out to hit the call button, gently hold your foot on the brake just enough to keep the rig from rolling. He claims setting the brakes fully causes unwanted downward pressure and thus, not giving an accurate reading. It makes sense in a way, yet it doesn't. Has any one else heard of this or can offer any input?
    passingthru69 and bzinger Thank this.
  3. Chinatown
    Chinatown Road Train Member
    73,251
    164,562
    Aug 28, 2011
    Henderson, NV & Orient
    It's the bind that can cause that. Trailer brakes pulling against the truck tandem brakes because the trailer brakes and truck drives are on seperate scales.
    I set either the trailer brakes or the tractor brakes, but not both.
    tscottme, Moosetek13, x1Heavy and 2 others Thank this.
  4. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
    I always set my brakes and shut off my truck.
    I've gotten scaled at scale houses and the weights match.
    You just to be close on your axle weights while staying under gross.
    Mainly they are looking for the goof in the rocket scientist thread.
  5. motocross25
    3,805
    11,487
    Sep 23, 2010
    Overland Park, KS
    Yep "the bind" is the phrase I was searching for. That's how he explained it too. Thanks for the advice I'll set one or the other next time
    Chinatown Thanks this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Set your trolley on that scale, release it on the call button, let her float a bit. But don't release it all the way. Just a little bit.
    Also, try to glide onto the scale without any power, just idle up to it and let her get on. Once on, be gentle.
    I love how the english language comes out just so. ugh....
    G13Tomcat, motocross25 and gokiddogo Thank this.
  7. slim shady
    slim shady Road Train Member
    3,468
    14,689
    Sep 14, 2011
    Chicago, Il.
    I never set my brakes on the scale
    Scales are flat and level you wont roll off and if you do that scale wont be accurate
    In my case I pull a tank so I have to let the liquid settle down to get an accurate weight
    Longarm, fargonaz, G13Tomcat and 3 others Thank this.
  8. driverdriver
    driverdriver Road Train Member
    4,254
    5,282
    May 30, 2011
    Just leave it in gear and shut it off.
    Big_D409 and motocross25 Thank this.
  9. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    If you have a trailer that dumps the air bags when you pull the red trailer button, these are what can cause the biggest weight shift anomalies when you do a full brake set on the platform.
    Recommend either only set tractor brake or, in gear, engine off
  10. okiedokie
    okiedokie Road Train Member
    11,677
    84,538
    Jun 13, 2011
    PNWET
    We use to pull weight off of axles while rolling the scales.
    motocross25 and Getsinyourblood Thank this.
  11. Heritage11
    Heritage11 Light Load Member
    120
    274
    Jan 6, 2017
    Ours do this. When the trailer settles as the air dumps, it pushes the kingpin against the 5th wheel and the binding causes the weights to read light on the drives and heavy on the tandems. I've seen it off by as much as 1500lbs depending on the load and distribution but generally it's a couple to 500lbs. Only took twice for me to realize what was happening and never had an issue after that.
    setting the tractor brake only gets an accurate weight
    x1Heavy and motocross25 Thank this.
