Brake shoe won’t sit properly
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by RoadRanger^^, Dec 12, 2024.
  1. RoadRanger^^
    RoadRanger^^ Light Load Member
    265
    105
    Apr 17, 2018
    Columbus, OH
    Hello,
    I replaced brake shoes on the trailer and replaced anchor pins too, well on of the brake shoe driver side front axle top shoe won’t sit properly on the drum while bottom lines up fine. Today my brakes locked up and later when i check that brake i see the top shoe touching the lip of the brake drum and with the brakes released i could not move the slack it was locked, i reused my old drums. Will new drum fix my issue does anybody have this issue ? I saw some post somebody says its fine but this does not look right to me
  3. Diesel Dave
    8,522
    23,454
    Jan 20, 2010
    Hesperia, Ca.
    Did you buy and check the shoes ? I had a Fruehauf trailer back in the day, I had bought shoes and didn’t check them, they didn’t fit. Found out later they had 2 type of shoes. Check yours…..
    Rideandrepair Thanks this.
  4. RoadRanger^^
    265
    105
    Apr 17, 2018
    Columbus, OH
    I bought 4 set of brake shoes and all of them were 4707 I’m pretty sure they are correct
    Rideandrepair and Diesel Dave Thank this.
  5. SmallPackage
    5,278
    16,463
    Dec 20, 2019
    Marion Texas
    Sometimes the linings sit a hair or two off center of the shoe saddles when riveted. The edge of lining may be catching the wear lip on the drum just enough to stick. Either swap top shoes side to side or grind a bit off the shoe edge for clearance.
    Rideandrepair and RoadRanger^^ Thank this.
  6. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    How old are the drums? Is it possible that you have a cam roll over situation?
  7. wore out
    wore out Numbered Classic
    15,335
    185,119
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Was the old shoe square under the drum? If so a shoe problem. If not it’s going to be the spider or backing plate whatever they are calling it theses days
  8. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    Did you use a sledge hammer to get the anchor pins out?
  9. RoadRanger^^
    265
    105
    Apr 17, 2018
    Columbus, OH
    I used hammer for a few times but i realized that they are not coming off that easy so i rent a tool from autozone and drove them out and a lot of heat.
    I installed today new s cam, s cam bushing (tube), installed new brake drum as well and also installed sleeved nuts to center the wheel just in case if something wrong with the hub. I finished everything adjuster the brake, 1/2 turn back but there is still big gap between the shoe and the drum. Is there a chance that these brake shoes are defective? i don’t know why they would not adjust, push rod travel is like 1/2 inch or something and now i’m wondering if brake shoe is touching the drum when I’m braking with that big gap. Thank you for all helping
  10. RoadRanger^^
    265
    105
    Apr 17, 2018
    Columbus, OH
    They were aligned correctly as i can see from the drum, had no issue before i replaced with this new shoes
  11. wichris
    4,243
    8,447
    Jan 17, 2011
    Sure you got the Q+ cams and not standard?
