HI
I have 4 faults on Freightliner Century 2007 autoshift
1/ Brake rtdr control rly open 136s013 05 code what is this
2/Radar Bad 219s248 12
3/Radar Errati 219s002 02
4/ Radar errati 219s009 02
Brake retarder control relay open
Discussion in 'Freightliner Forum' started by majk, Oct 25, 2013.
07 Freightliner got ABS-E (D+) by Wabco, made in Wrozlaw, Poland. This unit is used on EU and NA trucks, according ECE laws if rear wheels lock ABS unit MUST disable brake retarder, engine brake (exaust flap ore jakes).
So they install retarder relay. its contacts are used for engine "jakes off" inputs. But now they use J1939 communication. Sometimes after ABS ECU swap this code appeares till u disable retarder relay and activate J1939 with Wabco ToolBox software.
MID 219 is Collision Avoidance Radar, may be VORAD Radar, may be MB Distronic......
well 248 - no communication with radar senor. 002 and 009 - erratic data from radar
There is a small relay on the front of the pdm on the dash, that gets flipped around a lot. Pull your relays one by one straight out, and see if the middle pin on the relay match with the pin in the relay holder
On the passenger side on the dash, where fuses are located
RIGHT??? -
Yep, when you open the cover, the relay will be one of the small ones, closest to you in the middle (ish) pull it straight up and check the orientation of the pins.
Please help I got the same code and I can't figure out where that retarder relay is located?!
You might want to call freightliner, these post are 4 years old.
. hi did you get if fixed? I got the same code, please let me know Thanks
