My brake pedal vibrates when applied. Truck stops fine, doesn’t pull to right or left. Slight vibration from pedal when on rough road also. I’m guessing air system? Anyone experienced this before? Thank you.
Brake pedal vibration
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Steve2804, Mar 26, 2019.
Front wheel bearings? Are your front tires cupping?
Disc brakes? Or drum?
if a disc brake, could be a warped rotor. -
Maybe hydraulic brakes you would get back feed into brake pedal for out of round drum. Would be the first I ever heard of in an air brake system. But hey, who am I lol
At least one of your drums are bad. There isnt anything else i can think of capable of transferring pressure back to the service brake pedal. However if that is the case the whole truck will not be feeling well during the braking.
x1Heavy Thanks this.
