Brake lights staying on
Discussion in 'Freightliner Forum' started by Tmiller444, Apr 3, 2023.
  1. Tmiller444
    Tmiller444 Bobtail Member
    4
    I have a 2012 freightliner cascadia, my brake lights are staying on. I replaced the brake light pressure switch and they still stay on. Any recommendations?
  3. SmallPackage
    5,273
    16,440
    Dec 20, 2019
    Marion Texas
    Does the cascadia use a switch on the brake pedal itself. I now the older business class cabs do. If it does the switch is either out of adjustment ( not touching pedal to click it off) or bad contacts inside it stuck in on position.
  4. tscottme
    tscottme Road Train Member
    I've heard brake lights staying on can be a symptom of a bad ground wire.
  5. Antinomian
    Antinomian Road Train Member
    2,076
    3,241
    Feb 17, 2013
    Do your trailer brake lights also stay on?
    When you unplug the pressure switch do the brake lights go out?
    Do you get rain water on your firewall near the SAM Chassis (driver's side)?
  6. bzinger
    bzinger Road Train Member
    16,593
    65,733
    Dec 10, 2014
    omaha , ne
    There is a light control module behind the switch panel that the 4 way flasher switch is in and it goes bad , mine with installation at a freightliner dealer was less than 200.00.
    When mine went bad I had no brake lights .
  7. Tmiller444
    4
    No, trailer lights work perfect. Unplugging the pressure switch the lights stay on. No rain water, but it occurred after I had the exterior washed and the rear ended degreased, hood was not opened.
  8. Tmiller444
    4
  9. Tmiller444
    4
    Trailer light work perfect.
    Unplugging pressure switch and lights still stay on.
    It occurred after having an exterior wash and the rear end degreased, but the hood was not opened.
  10. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    Trailer brake handle accidentally touched ?!...
  11. Antinomian
    2,076
    3,241
    Feb 17, 2013
    The rain pan under the windshield has a two sided sticky gasket between it and the fire wall. If you have ever had it off the gasket is ruined and will not reseal. I like to run a silicone bead along the top to seal it. Bizarre light behavior can be caused by water in the SAM Chassis. Do you have a way to check for codes? Do you ever see water on the firewall?
