Brake light switch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by spindrift, Mar 20, 2020.
  1. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
    Trying to locate the brake light switch on a 2004 Pete 379. Lights won't go off when truck is off, or running.
    truckdriver31 Thanks this.
  3. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    brake light switch is around brake pedal. try putting ur toes under pedal and pulling up.
  4. spindrift
    3,233
    12,905
    Dec 2, 2014
    Texas
    The only thing I see under the pedal is a "plunger" that's inside of what appears to be a rubber donut. That assembly is bolted to the floor where it connects to an air valve on the underside of the floor.
    I had aired down the truck to get a better look at what's under the pedal. Odd thing was that the cruise control set switch was very lazy increasing engine speed in order to get air pressure back up. Now, when I turn off cruise, engine rpms do not drop. Another way to turn off the cruise has been to depress the clutch pedal. That method no longer works. Are cruise control and brake lights somehow connected?
  5. DmitriyKW
    DmitriyKW Bobtail Member
    47
    65
    Feb 10, 2015
    Sacto, CA
    I think brake light switch is located in your dash where your gauges are and it works by air, you press a pedal and you trigger that switch. Google how it look like. When you press pedal you can hear it clicks each time you press. If not then it got stuck in one position.
    Rideandrepair and truckdriver31 Thank this.
  6. spindrift
    3,233
    12,905
    Dec 2, 2014
    Texas
    Well...
    Let me say this about that. Sometimes, it's the simple things in life. Wait for it....
    The Johnny bar was pulled ever so slightly!!
