Brake chamber question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Socal Xpress, Sep 11, 2020.
  1. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Whats the difference square port vs round. Gc3030 standard stroke. Had #2 axle chambers replaced over 4 years ago and I ended up with 1 of each. Replacing the pair again and looks like both will be round. TIA
  3. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
  4. Dave_in_AZ
    369,869
    Wrench told me the long stroke are the parking brakes.
    True????
  5. AModelCat
    154,243
    False I'd say. Square port just means they stroke 3" on a type 3030 vs 2.5" on a standard 3030.
    I hope I'm listing the correct stroke lengths. Its been a few years lmfao.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    If you use a long stroke on a regular brake setup you may wind up camming over the S cams. Then you have no brakes. You cannot substitute Willy nilly .
    Socal Xpress and Dave_in_AZ Thank this.
  7. HoneyBadger67
    2,056
    4,511
    Dec 15, 2018
    Savannah, TN
    Round should be short stroke, square should be long. The tag is probably long gone, but you can check for stamped indentifiers on the steel housing. Scrape off the rust and grease and read the stamping.
    FYI and very important: do not mix short and long on the same axle!
    Dave_in_AZ Thanks this.
  8. pushbroom
    1,777
    7,253
    Sep 1, 2012
    A longer stroke brake pot cannot over cam brakes. The only way to over cam a brake is by severely worn brake shoes or drum.
