braided stainless steel air lines
Discussion in 'Trucks [ Eighteen Wheelers ]' started by turboguy, Jul 11, 2016.
  1. turboguy
    turboguy Light Load Member
    132
    23
    May 16, 2015
    Is anyone running braided stainless steel air lines?
    what are the pros vs cons?
  3. Yves kanevil
    Yves kanevil Medium Load Member
    522
    465
    Jan 10, 2016
    Nighthawk
    They last longer but in event that they do leak entire hose needs to be replaced instead of throwing a union on and getting back to work
  4. stayinback
    stayinback Road Train Member
    3,911
    8,255
    Jan 24, 2014
    chicago,il
    eggs-Ackley^^^
    Braided Looks good..But I'll stick with the plastic...Easy Fixums anywhere on the truck.
  5. AModelCat
    154,488
    Pros:
    -A lot more durable than synflex air line. Can withstand heat/sparks better. More resistant to chaffing.
    Cons:
    -Higher cost.
    -Not as quick to repair.
    -Larger and heavier.
    -Not as flexible. Get very stiff when they're old (like these).
    turboguy and x1Heavy Thank this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    If you can keep the actual air hose under all of that rubber you will not break them so easily in -50 up there in the Dakotas doing a simple circle when setting up a park for the night.
  7. turboguy
    132
    23
    May 16, 2015
    How do they hold up in winter conditions with roads that are sanded?
  8. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Not sure I understand the question .
    Are you talking about the air lines going to the trailer or all the air lines through out the truck.
    There's really only 2 types of airline trucks come with from factory. The synflex plastic air line or double braid rubber air line.
    The only stainless steel air line on the whole truck is the hot line coming off the compressor.
    The plastic air line is far superior in every way . No one orders a truck with steel braid air lines anymore.
    Actually own a truck for 20 years then tell me how much you love that braided air line. You'll end up replumbing that same truck with plastic.
    If your actually talking about having true stainless steel braided line thru the whole truck then you must have money to burn. Cost a fortune and no benefit over plastic except maybe the Wow factor.
    Bean Jr. and Boardhauler Thank this.
  9. turboguy
    132
    23
    May 16, 2015
    thats correct I am talking about replacing the stock lines with steel braided line thru the whole truck. Its a single axle tractor with a short wheelbase.
  10. AModelCat
    154,488
    That pic of that big pile of steel braided line came out of my W9. Being replaced with plastic.
    Big Road Skateboard Thanks this.
  11. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Exactly!! Now you know what I'm talking about. It's heavy , takes up twice as much room and over time will rust from inside out.
    I've never seen or heard of any one doing SS thru out the whole truck , prob for reasons I've mentioned above.
    Nothing wrong with plastic that's routed nicely and tied up with no rubbing any where.
    Looks nice and lasts virtually forever .
