Boxes on trailer for chains
Discussion in 'Flatbed Trucking Forum' started by Bdog, Apr 3, 2017.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    I have a 53' step and a nice enclosed headache rack that holds all my chains and binders. I haul equipment mostly and have not used a strap in over a year. Anyway my headache rack keeps things nice and organized and untangled but it gets old climbing up there to get everything and put it back especially since my average load takes 12 chains and binders.
    Do the boxes on the trailer work good? I was thinking maybe four of them two on each side one at front and one at the back to minimize hauling stuff back and forth.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Ive had boxes on the trailer before with the Ravens and with the fuehaufs. You are trading stooping over to pull the canvas and securement etc. It so happens being stooped over is a stress position against your body. It's better to climb up to your headache rack, you can then swing the stuff to your deck rather than lift it up above the deck height. If mr chain escapes from the box chances are one of your duals are going to eat it and it will not be good.
    Considering the potential of lumping and lost time with all other kinds of trucking, throwing chain or climbing is the least of the problems.
    rolls canardly Thanks this.
  4. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    This is how I store my chains in a side box. Screenshot_2016-05-19-11-57-48.png
    Lepton1, Logan76, BigCam9670 and 11 others Thank this.
  5. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    Do you need the equipment for more than one trailer? If you organize it like MJ did you could put one box on each side and have plentry of room. I have an enclosed headache rack for stuff I only need once in a while. I use my step boxes to hold the chains I use the most.
    MJ1657 Thanks this.
  6. Razororange
    Razororange Road Train Member
    2,445
    23,103
    Dec 20, 2011
    Milwaukee, WI
    This is how I have my chains. I have 2 boxes on the tractor and no headache rack.
    Logan76, Jazz1, lynchy and 9 others Thank this.
  7. MJ1657
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    The dividers in the bottom of the box are a good idea.
  8. Razororange
    2,445
    23,103
    Dec 20, 2011
    Milwaukee, WI
    I like them. I need to have a plate welded across the front at some point to keep the links from jamming the door.
    I also wish they were taller. The are just barely high enough to keep a single 20ft 1/2" or 2 20ft 3/8" chains contained in one section.
  9. rolls canardly
    rolls canardly Road Train Member
    1,597
    3,726
    Feb 7, 2009
    mt. pocono. pa.
    I always wondered how does a chain get a knot in it if I keep the hook ends together?
    I may just steal your divider idea, Razororange.
    Looks like a professional display; good job.
    X1 HEAVY makes several good points above, and there have been ergonomics studies supporting his assertions about dropping the chains/binders down vs. lifting them.
    I'd stick with the system you have - and add a ladder? I'm 63 and jumping up and down from the deck several times is getting to be too much, so I go to the cab steps and swing on the deck from there.
    Then theres that - the Mr. Chain escape route thru your duallys and around the axle.
    Reason for edit: out to lunch
    MJ1657 Thanks this.
  10. rolls canardly
    1,597
    3,726
    Feb 7, 2009
    mt. pocono. pa.
    I have boxes on both sides; and they look nothing like MJ1657 or Razororange. They're a mess.
    I am thinking of adding another two further back. For the overflow.
    My problem is that I end up with an entire other set of tools in the truck,
    in addition to the tools stashed under the passenger bench seat.
    (I gave up trying to return them to the garage and the half-empty 7 foot Snap On box,)
    I keep the delicate, or specialty type of tools in cab under seat, and fastener stuff in the boxes.
    Then theres the torches, the 20 ton air bottle jack, 2 tire bars, all the pry bars, 1 ton come-alongs, etc.
    I have a box labeled "BASHING TOOLS" for the delicate work. Sledgehammers, etc. Watch repair.
    Heck, I could do roadside repair with all the crap I tote around.
  11. Jumbo
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    They only problem with your "Dropping the chain vs lifting them" assertion is that you have to eventually lift the chain back up to put it in the headache rack. I would rather stand on the ground and grab a chain out of a box than stand on the deck of my truck and lift 12 chains up to put them away every time I unload.
    snowman_w900, cke, MJ1657 and 2 others Thank this.
