I am just finishing up my time with my road instructor and I noticed at truck stops there is DEF in boxes for $14.99 for 2.5 gallons and DEF at the pump for $2.79 per gallon. DEF at the pump is a much better bargain. Are there any advantages to buying boxed DEF instead? Thanks!
Boxed DEF versus DEF at the pump
Discussion in 'Questions From New Drivers' started by Truckermania, Aug 17, 2014.
Page 1 of 4
Maybe buy a Box to keep for Emergencies.
Otherwise get it at the pump.
At the beginning it was hard to find at the Pumps.
Shouldn't be a problem anymore. -
Exactly right, as the boxed option used to be the only option at many stops before the new pumps were installed. It's nice to be back in a truck that doesn't use DEF, but I know that time will come to an end at some point.
it's all the same stuff. why they carry so much though, is beyond me.
It must sell or they would not stock it. So long as you add DEF at every fill up I don't see why you would ever need to buy Boxed DEF. -
Some trucks have the DEF tank on the right side. It's a lot easier to buy the boxes than it is to try and fill at the pump.
Here is a fact,, DEF is 65% water
Perhaps they carry it for those that don't. know how to get it at the pump.. or can't get it at the pump.. i still find truck stops that don't have def in the fuel isle but its rare for me to fuel up at these locations ... in the winter.. def pumps do freeze up
Some of the early DEF Trucks had the Tank on the wrong (right) side.
Most trucks now should have the Tank on left side.
For a while it seemed a lot of them weren't working/frozen or whatever.
I ended up getting it a lot lower then I really wanted.
The Cascadia doesn't have a real gauge, has 4 indicator lights/squares.
. I only add DEF when it gets down to 3 or less, which is usually every other Fillup or so.dca Thanks this. -
... so now you can smell all pretty when you climb back in your truck.
The only time I ever bought DEF in a box was in Illinois last winter. The temperature was about 5ºF and signs were posted that DEF wasn't working at the pump. We were low so I went in to buy it in the box and the cashier explained the DEF was getting ice crystals in the tank and wasn't flowing. It's a messy and frustrating business using those boxes.
Page 1 of 4
