Blue dash button COE tractor
Discussion in 'Trucks [ Eighteen Wheelers ]' started by blackmagic08, May 24, 2013.
  1. blackmagic08
    blackmagic08 Bobtail Member
    13
    May 7, 2013
    Danbury, CT
    I noticed in some pictures of a ford and into cabover tractor a blue button next to the red and yellow park brake buttons.. search provides no clues. What is it?
    Sent from my HTCEVODesign4G using Tapatalk 2
  3. RickG
    RickG Road Train Member
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    http://www.michigan.gov/documents/Section_5_-_Air_Brakes_109900_7.pdf
    Older trailers did not have spring brakes and would have no brakes on when parked . Applying air set the brakes .
  4. CbarM
    CbarM Heavy Load Member
    894
    247
    Jan 17, 2011
    Irvine, AB
    I have wondered about this for some time also...why would there be all 3?
  5. CatPowerC15
    CatPowerC15 Medium Load Member
    347
    90
    Feb 18, 2010
    Siler City, NC
    The red is trailer, blue is tractor, and yellow is both. These older trucks also do not seperate brake lights and signal lights on the trailer. Brake lights will illuminate the side blinkers.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    some old vehicles had addtional button - park brake valve air saupply. It pops out when park brake tank air pressure is lower 75 PSI.
    Now this button is used on Scandinavian trucks. They are equiped with combined European park brake valve (one stick, no buttons) and this button valve. If truck loose air it pops up and park brake valve wont working till you push this button.
    DOT and ECE do not require it, but Scania and Volvo use this valve
    CatPowerC15 Thanks this.
  7. blackmagic08
    13
    May 7, 2013
    Danbury, CT
    This is very interesting, thanks for the replies.
  8. RickG
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    Last year a QC driver had a trailer come unhooked so corporate safety e-mailed every driver instructions on how they taught us to hook a trailer . Their instructions said to put the trailer parking brake to "emergency" to apply air to the trailer brakes .
    I replied and asked them to send more detailed instructions , preferably with photos because I couldn't find the trailer parking brake they described . I never got a response .
    cetanediesel Thanks this.
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Trailers made after 90s got all PREV valve. If you disable air supply (red button in off position) ore red glad hand separated trailer brakes are locked. some trailers got buttond to apply/disable brakes (red and black buttons), but ther work if trailer air tank is not low. On some trucks, like Volvo FH and VN, some Freightliners there are trailer hold switches (electrical ore air). If you turn trailer hold on blue/yellow (service brake) glad hand is pressurized. But never use this button for parking - pull both red and yellow buttons.
    It is not all, some old trailers got no PREV and spring brake. They used chocks ore trolley brake!!!!!! I advice everyone to convert air system of old trailers to new DOT and ECE requriments
  10. SCHULTZ
    SCHULTZ Light Load Member
    152
    50
    Oct 21, 2011
    On my 78 freightliner it was to release springs if I lost air there was a separate air tank to allow you to move the truck if breaks locked up
