Blown shock oos?
Discussion in 'Experienced Truckers' Advice' started by sbaumann14, May 23, 2019.
  1. sbaumann14
    sbaumann14 Road Train Member
    1,215
    1,389
    Sep 1, 2010
    Rhinelander, WI
    Is a blown shock an OOS on a road check? Just noticed this a.m. on my pre check.....oil on the body, so its blown. Want to get home to change
    D.Tibbitt, Rideandrepair and sevenmph Thank this.
  3. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    Yes it is.
  4. dibstr
    dibstr Road Train Member
    1,308
    931
    Sep 10, 2010
    No it’s not. The NASOOSC specifically states that “ A shock absorber is not a suspension connecting rod. A defective shock absorber will not result in an OOS condition.” Page 53.
  5. 062
    062 Road Train Member
    6,142
    33,155
    Oct 20, 2013
    Brake cleaner and a rag. Just don’t forget to replace it.
  6. spyder7723
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    Ya ever read something and for whatever reason your brain crosses wires and thinks it read something entirely different?
    The op clearly states out of service but my brain read tiicketable offense with cvsa points. And i wasn't even drinking last night! Maybe that's the problem.
    Petty Cash, rank, D.Tibbitt and 3 others Thank this.
  7. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    There's no way for them to tell the shock is blown.
    And unless they happen to see the oil immediately. It dries off really quickly. Yes. I've seen it happen on truc.ks I drive
    They can see worn bushings and they'll probably say something.
  8. dibstr
    1,308
    931
    Sep 10, 2010
    I do it on a daily basis...my wife says it’s on a minute to minute basis.
  9. sbaumann14
    1,215
    1,389
    Sep 1, 2010
    Rhinelander, WI
    I can look down and see oil on shock....I'm guessing so can an inspector
  10. spyder7723
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    If you don't have the tools with you to change it now, do what was suggested above and clean it up with brake cleaner. It only has so much oil in it, in a couple days there won't be any left to squirt out.
  11. mtoo
    mtoo Road Train Member
    1,928
    4,427
    Jan 15, 2011
    Retired on bended knee
    When stuff like happens and you can't or don't want to fix it on the road. Always clean it up and do what you have to do to make it less obvious At least make the inspector have to look for it. Instead of the problem jumping out at the inspector and saying (look at me!!!!!!!!!!!!!!!)
