Blowing Fuses 12V Coleman Thermoelectric
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by BoazTrucker, Nov 9, 2014.
  1. BoazTrucker
    BoazTrucker Light Load Member
    117
    49
    May 3, 2013
    Northeast Alabama
    Ok I am pretty knowledgeable when it comes to 12V systems, but this one has me stumped.
    I am running a 2011 FL Cascadia, the Coleman cooler is the older blue one, and I had just ordered a new outer fan that blows into the heat sink. I have a 12v plug with a ACG fuse in the tip. My truck doesnt often get shut off idling through the night. Well after replacing the fan, I have has a problem blowing the ACG fuse in the plug, and one time actually the fuse located on the SAM of the Cascadia.
    My question is why would it be blowing the fuse, voltage spikes? How can I correct this problem, I assume if I use a 10 Amp fuse, its pulling too much power and will get hot and melt plug, (learned that already)
    I am stumped.
    My other options are to buy a brand new cooler, or an actual fridge for my truck, but i dont really want to cough up 600 bucks for that.
  3. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    Cut the wires as attach it to ur inverter wires or run it to another fused system. Ended up having to do this as mine kept blowing fuses and melting the plug. Its worked like a champ sense then that was 2 years ago. I added a toggle on off switch to the setup also.
    Cooler ended up dieing here a few months ago and ended up getting a factory fridge.
  4. Balakov100
    Balakov100 Road Train Member
    3,937
    2,635
    May 10, 2012
    Temple, TX
    It's the Truck lol.
    I used to Slipseat
    The Truck I originally had the Cable didn't get hot and melt the plug all the time.
    On some of the Trucks the cable/plug had a tendency to get HOT really hot and eventually melt, as well as blow the fuses.
    So..Not sure why/how but for me it only seemed to happen on some.
  5. OFTOTR
    OFTOTR Medium Load Member
    653
    678
    Jul 19, 2011
    Toccoa GA
    Try a new plug/wire assembly, and maybe a different socket.
    This is just a fact of life with these 12v coolers.
    I try to use a plug that has an led on it so I can look over and see its still running. I've even added an led to a few of the coolers I've had.
    Too often they blew a fuse or died and I didn't notice for hours. Food got warm.
    If you hit a big electronics store like frys you can even find a 12v fan that has some leds built in, for less than ten bucks. These are for pc case fans for gamer types, but you can usually find one that will fit and work.
  6. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Maybe the replacement fan they sent you is defective? To me, that's not hard at all to consider as a possibility.
    X-Country Thanks this.
  7. conjuntoron
    conjuntoron Bobtail Member
    34
    31
    May 29, 2014
    Pasadena, Tx
    I'm not an electronic expert, but I had the Coleman 40oz cooler and the fuse burned out and melted inside the adapter.
    I said screw it and bought an Igloo 40oz Iceless cooler a few months agao and it's been working fine. It's only about $100 if you just want a less expensive one. I haven't been able to invest alot of money in one of those $600 coolers yet, maybe one day. They must be ###### costing that much.
    lovesthedrive Thanks this.
  8. Xcis
    Xcis Medium Load Member
    498
    270
    Jul 9, 2008
    Bridgeport, Pa
    When a fuse blows,it is caused by drawing to many amps not a voltage spike. The fuse is a safety device for your protection. It prevents really expensive damage to circuit components. Replacing a fuse with a much higher amp fuse can lead to an electrical fire. If a fuse keeps blowing there is an electrical problem with the unit that needs to be fixed.
    conjuntoron Thanks this.
  9. kgoettl
    kgoettl Bobtail Member
    Saint Clair, MN
    Glad to see I'm not the only one who had trouble with melted plugs on these coolers.
    I finally cut the wire close to the cooling mechanism, used 12ga wire, put, an "eye" end on both power and ground wires and hooked them to their respective studs on my inverter, coming off battery. Used 20 amp inline fuse at the inverter stud.
    Been working fine for 4 mo now.
  10. marmonman
    marmonman Road Train Member
    1,417
    2,842
    Dec 14, 2009
    central illinois
    I have removed all the cig plugs from my burton stove and igloo cooler and went to Anderson power poles .
    I have a power source right from the batteries ( fused of course) with the power pole connector on it both work better since the switch and no more hot plugs !
    I am in the process of upgrading the fans on the cooler as I type this so it should do a better job of moving the air inside and out !
    MsJamie Thanks this.
  11. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    One thing I found after I melted the an inverter plug a few times. Take a cable tie or a plastic fork tong and slide between the plug and the connector. Sometimes the plug will slide out a hair or two and have an "air gap", causing it to draw more current. Hence the melted plug syndrome.
