Blower attached to pneumatic trailer??
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Woodys, Oct 26, 2018.
  1. Woodys
    Woodys Heavy Load Member
    774
    1,629
    Mar 16, 2010
    Tampa, FL
    In the picture, it looks like the blower is attached to the tank? This is the first time I've seen it not attached directly to the truck. How does it work?
  3. Blackshack46
    Blackshack46 Road Train Member
    Curious myself, is it just the blower? Or is there hookups for the piping/hydraulic hoses and pto?
    Woodys Thanks this.
  4. Woodys
    774
    1,629
    Mar 16, 2010
    Tampa, FL
    No clue. The trucks have pto and the hydraulic fittings, so I'm assuming they connect to the blower somehow??
    Blackshack46 Thanks this.
  5. Suspect Zero
    Suspect Zero Road Train Member
    2,497
    9,423
    Oct 10, 2016
    Burbank, IL
    Not to sound stupid here, but is it just the air intake/filter assembly and he has to run a hose from it to the blower on the truck?
    Woodys Thanks this.
  6. Suspect Zero
    2,497
    9,423
    Oct 10, 2016
    Burbank, IL
    Nevermind, didn't see this post pop up while I was making mine.
    Woodys Thanks this.
  7. Blackshack46
    Do you have a picture of the whole trailer? I suspect that pipe on the side goes to the motor/compressor.... i could also be dead wrong.
    Woodys Thanks this.
  8. Blackshack46
    Google.... so smart and so dumb at the same time. Screenshot_20181026-133853.png
  9. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Schlumberger has compressors mounted on the front of their penumatics
  10. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    If the blower isnt driven hydraulically from a PTO/WETKIT on the truck then its most likely driven by a small diesel engine.
  11. REO6205
    REO6205 Road Train Member
    13,172
    60,483
    Feb 15, 2014
    California.
    We had 2 pneumatics with a 3cylinder 27 hp perkins and a compressor mounted on them. We used them to haul flyash or boiler ash from co-generation plants for soil stabilzation. We could drop the trailer on the jobsite and the spreader trucks could fill up without us being there.
    You could also use them to pressurize rail cars for unloading but we didn't do that much.
