Blowby Smoke
Discussion in 'Trucks [ Eighteen Wheelers ]' started by superhill56, Dec 5, 2017.
  1. superhill56
    superhill56 Light Load Member
    216
    94
    Jul 28, 2016
    Powdersville, SC
    I have a 06 Cummins ISX that I have had about 7 months. Got 818,000 miles on it. I'm starting to get more noticeable blowby on it but it seems more like steam than smoke and kind of smells like coolant. Anybody know what my issue could be. It will also have a drop of oil fall every couple of minutes. I'll attach a vid if I can. Thanks guys!
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Are you loosing coolant or oil? Get an oil sample done, that is the best place to start, it can tell you if there is something going on with your motor that shouldn't be.
  4. superhill56
    216
    94
    Jul 28, 2016
    Powdersville, SC
    Add coolant every couple of months and add a gallon of oil between oil changes.
  5. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Its best to buy a oil sample kit at truck parts store and send off a sample of oil before next oil change just to see if any coolant is in the oil, you can send your e/mail with kit to help speed up the news?
    PS If you see any milky oil on fill cap its a bad sign
  6. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    Mine is an 07 isx had 300k on an inframe was doing same thing, injector cups were leaking on head was replacing head and found that all liners were scored. After inspecting pistons had 3 of them with the rings lined up so another inframe.
  7. superhill56
    216
    94
    Jul 28, 2016
    Powdersville, SC
