Block heater plug in issues
Discussion in 'Kenworth Forum' started by mhallam, Feb 19, 2013.
  1. mhallam
    mhallam Light Load Member
    61
    36
    May 15, 2012
    Saskatoon, Saskatchewan
    Is it just me or has anyone brought home their Kenworth truck and went to plug in the block heater in the receptacle under the drivers door and went wtf? For some reason my 09 and now my 12 has a unique plug end, basically a sideways blade on the left. Anyone know why? I went out and bought 2 special ends (not something small town hardware shop carries) and rigged up a 8" cord with a chunk of extension cord. Well it's finally given up on me and I need a new "end". Besides redoing the factory end with a normal plug in, are there any options? It's a pain cause I have to always make sure my cheater end is either with me, or in the shop or hangin off my deck. If there's a reason for this fancy end I'd love to hear it. Lol
  3. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Hello mhallam:
    I assume this is the plug you are describing? If so, it is a 120V 20A plug. I dont know the watt rating of your block heater, but most heaters south of the 49th parallel are 1500 watt? Watts divided by volts equals amps. 120V/1500W=12.5A
    I see your up north so maybe your heater is a higher rating? If you had a 2000W heater it would excede the 15A rating of "standard" household plug and most likely the wire, causing excessive resistance and possibly overheating(potential fire). 120V/2000W=16.7A
    JohnP3, 379Longhood and others from CA will be able to give you the best answer...
    :biggrin_25514:
    mhallam Thanks this.
  4. black_dog106
    1,786
    1,666
    Mar 29, 2009
    MA
    Hello again mhallam:
    After some more thought and research, there are two possibilities. One is rated for 120V, the other for 240V. Both are 20A connectors. I suppose there is the possibility of a 240V element? As said before, John, Jim or someone from your area will have a better answer for you. I apologize for not getting both options in first post... David
    http://www.stayonline.com/detail.aspx?id=6757
    http://www.stayonline.com/detail.aspx?id=6756
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    Instead of 240V I'd bet it is a higher amperage 120V connector, like those used in RV powercords. You might have better luck finding an already made cord at an RV shop.
  6. Hanadarko
    Hanadarko Independent Owner/Operator
    2,962
    927
    Oct 1, 2009
    Midwest
    A normal plug with one blade sideways is a 20A plug/socket.
    Can't you make one up with parts at Lowes or Home Depot?
  7. Bayle
    Bayle Road Train Member
    3,060
    1,227
    Aug 30, 2007
    Cottage Grove, MN
    Yep just like most kitchens, bathrooms, and outdoor plugs. That's why they have that sideways slot, 20amp. If you make one up make sure you use 12 gauge wire.
    mhallam and Hanadarko Thank this.
  8. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    25(2)+2 Thanks this.
  9. Brauner
    Brauner Bobtail Member
    I have the same problem, I installed a 20 amp cord end but after a while they dont seem to connect properly, the weight of the cord seems to pull the plug down far enough and we have been getting some arc ing , When I got to work this morning the plug was completly burnt. not cool seeing as its a super b fuel hauler. We have 9 T800 Kenworth all with the same problem there must be a solution out there somewhere
  10. Bayle
    3,060
    1,227
    Aug 30, 2007
    Cottage Grove, MN
    If its under the door over the step, a simple small block of wood to support the weight should do it. Or gett a longer cord wrap it around side mirror so the cable is hanging down and and not pulling itself out from its own weight.
  11. Brauner
    I will try that, thanks. Is it possible to change the socket on the truck to a 20 amp twist lock? wonder if anyone has tried that? I was thinking a plug similar to the one most generators have.
