Binder...log/permit book :?
Discussion in 'Swift' started by Sean_Memphis, Feb 25, 2015.
  1. Sean_Memphis
    Sean_Memphis Light Load Member
    289
    44
    Oct 9, 2014
    Memphis, TN
    One of the few things on my list of things to bring...is a binder....are they talking a log/permit book or just a standard 3-ring binder :? vinyl-snap-shut-log-book-cover-1-rvn-500.jpg zip-up-vinyl-log-book-cover-with-calculator-751-rvn-500.jpg
  3. inkeper
    inkeper Road Train Member
    1,440
    1,059
    Jan 30, 2011
    Texas
    3 ring binder, Actually you just need paper to take notes with. 3 hole to fit the binder would work. Take a fine point black pen to work on your paper logs. You won't need the log/permit book.
    The calculator is a good idea too.
    Sean_Reno Thanks this.
  4. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    And don't forget white out .
    inkeper and Sean_Reno Thank this.
  5. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    I used the white tape. Less messier. DOT had no issues with it.
    Sean_Reno and inkeper Thank this.
  6. MsJamie
    MsJamie Road Train Member
    I'm assuming that you are talking about use during training. A three ring zipper binder would be about perfect. Also, have a hole punch. Your log sheets will likely be copies, and not have holes punched in them. I used a spiral notebook (single subject from the dollar store) for my notes, which fit inside my binder when I was out on the range.
    Forget correction tape/juice. For logging class, corrections are not allowed.
  7. Sean_Memphis
    289
    44
    Oct 9, 2014
    Memphis, TN
