Big Cam III - Burnt Exhaust valve
Discussion in 'Trucks [ Eighteen Wheelers ]' started by harris2108, Nov 20, 2010.
  1. harris2108
    harris2108 Bobtail Member
    16
    What would cause an exhaust valve to burn on a Cummins Big Cam III.
    Its a stock engine. When we first looked at it I thought something metal had gone thru the cylinder. But the seat is pitted and the other valve looks like to the beginning of pits on it. This engine has 20K since an inframe.
    Bad Injector? we put another head on and that cylinder is running 10 -15 degrees less than the others.
    We reset all the valves and injectors and found some valve lash on the undisturbed heads to be a little tight. Could someone have set this one too tight?
    Recently the accessory drive shaft had broken off on a trip. A local shop repaired it. Could the timing gear have been assembled wrong and this be the cause?
    Would like to have a clearer picture of what went wrong before putting back to work.
    Any suggestions would be great.
    Thanks.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    sometimes bad injector, sometimes bad fuel with sulfur ore gas, sometimes when you drive your truck with floor gas at low RPMs, delayed shifting down (local overheating)....
  4. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    Too tight valve lashes burn valves.
  5. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    When the valve is off the valve seat during combustion in the cylinder it glows from the heat. The only way the valve can live is to transfer it's heat to the valve seat then eventually into the coolant through the head. If the valve is adjusted too tight, it will never hit the seat for heat transfer away from the valve. Tight valve adjustments will eventually kill the valves, causing sections to chip off.
  6. harris2108
    16
    We put on a good used head with low miles on it. It smoked heavily and #2 cylinder was running cold. So we changed the injector in #2.
    Replaceing the #2 injector ( same hole as burnt valve) cleared up the smoke.
    Double checked the valve clearances again. Everything seems okay now.
    The accessory drive we had fixed is now making a growling noise at idle that comes and goes. We called the shop that repaired it and they said they only put in a used shaft and did not replace the bearings!!. So I'll be pulling the accessory drive off tomorrow.
    Thanks for help, This was the first burnt valve I had seen in a Diesel. At first I had thought something had gone thru the engine.
  7. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    What he said.
    dutty_diesel Thanks this.
