Fixing to go the O/O route and every truck im looking at has the ISX.
I would like to do the EGR delete.
But im looking for the best reliablitly and cheapest to repair.
best year ISX to buy?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Fullforce, Jul 28, 2012.
IMO, Pre EGR ISX, no EGR, no VGT, no SCR/DEF/DPF.... 2002 year
thanks, but trying to find a truck with 400k to 700k so unfortunantly it will more than likely be 05 06 or 07 I think I read that the late 07 or the beginning of 08 is when the DPF's were added?
Im thinking of going to look at a 06 volvo with ISX and 500k miles, 10spd, 3.55's. I just know they change stuff up so much and dont want to get a bad year. -
The '07 was the year they made the switch to DPF, but those built b4 January of '07 (they start making the next model year in the middle of the summer) did not have the DPF. I have an '07 without. Been through a few EGR's in 500K, and have doubts about how much longer this original turbo will last.
Fullforce Thanks this. -
what a reason to purchase newer engine with expencive parts? '02 ISX is available rebuilt, no VGT, EGR!
Thanks hardlayover.
Pablo,Id LOVE to find a older truck that isnt beat to hell, but its practicaly impossible.
If I was going to go back to 2001 OR 2002 Id probly get a 6nz cat though.
I just want a truck thats not falling apart as soon as I buy it.
the egr will be removed and VGT will be swapped along with ecm reprograming within 2 months -
I use old CM570 ECMs to remove EGR and VGT (non VGT turbo is much chepper and I can use BW, Schwizer ore Garret, not Holset only).
CM870 require old fueling solenoids, but they are twice cheapper new123456 Thanks this. -
If you thumb through truckpaper you'll see that most, if not all, 99-03 trucks with an ISX have had the engine completely replaced...much like the early C-12's. But as you said, finding something without a gozillion miles is a challenge.
really lets compare pre EGR ISX w CM570 and Newer with CM870
Newer got new metering solenoidds (not compatible with other), new cyl. head with other timing, EGR and VGT. -
03 - 05 ISX also have a tendency to develop a leak in the head gasket on the drivers side rear of the head. Begins small and turns messy leaking oil all over the place. If you find one you like be sure to check this. Otherwise it's a decent engine. I have an 05 and it leaks there but still turns 97% of the factory HP rating and gets 7.9 MPG loaded.
