Best Year Cascadia
Discussion in 'Freightliner Forum' started by AlexD13, Dec 4, 2020.
  1. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    Hi, In the marker for a newer truck. Looking for a cascadia 2015-2018.. any insight? Also DD15 or Cummins, and What do you all think of the Automatic trans.
    Thanks!
  3. Condi
    Condi Light Load Member
    123
    128
    Sep 9, 2012
    Best cascadia is the one you don't own
    Cat sdp and Socal Xpress Thank this.
  4. AlexD13
    298
    85
    Jun 13, 2016
    Lol so what is better?
  5. Condi
    123
    128
    Sep 9, 2012
    Get full maintenance lease. If you cant afford it, stay company driver. Even a 2018 truck after year or two will get you in so much trouble you will regret you made this decision.
  6. AlexD13
    298
    85
    Jun 13, 2016
    Thanks for your Input. Get me that lease deal you are talking about, Im interested. Been an OP For 9 years have had my Volvo for 600k miles. Just wanted to see what people think about Cascadias
    bzinger Thanks this.
  7. bzinger
    bzinger Road Train Member
    16,593
    65,735
    Dec 10, 2014
    omaha , ne
    Got 894k on my Cummins powered 2013 now , wasn't impressed with an overhaul at 684k but that was a Cummins issue.
    Its been very well cared for and not beat , still tight and no issues you wouldn't have with any other make .
    I've owned freightliner, volvo, kw and international and all had theyre pluses and minuses .
    Drove some newer peterbilts that rained inside as much as outside and consider them way over rated .
    A truck generally will treat you as well as the first owner treats it / driver .
    I see lots of steering wheel holders pound the piss out of equipment they don't own so I take zero stock in theyre opinions.
    AlexD13 Thanks this.
  8. Scoot 1971
    Scoot 1971 Light Load Member
    265
    348
    Nov 22, 2018
    Got a '17 with DD15, we've driven this truck since new and I'm now looking at 902,632 miles on odometer. Literally just changed DPF last week after doing one cleaning of original DPF.
    We have APU and are a team operation so idling hours are low. I fully believe we will get another 2-3 hundred thousand miles before overhaul. Engine is still running great.
    Nothing has been replaced on engine except starter, a/c compressor and alternator.
    Have had a couple issues with SCR system and have been towed twice as a result. This engine has been really solid for us and showing a lifetime mpg of 7.6, we normally run around 75k gross along I-10.
    The DT12 AMT has been great with only one issue at around 600k miles when the spline shaft broke and took out a seal out back and put oil all over rear frame. It cost me 2 days and no money for repair as it was under warranty. Honestly, replacing all 4 wide drive tires has been our largest shop bill. If I were to buy another truck today, I would only buy one with a DD engine.
  9. AlexD13
    298
    85
    Jun 13, 2016
    Wow So glad to hear
  10. AlexD13
    298
    85
    Jun 13, 2016
    What Hp do you have?
  11. Scoot 1971
    265
    348
    Nov 22, 2018
