Best way to disable a driver facing camera
Discussion in 'Experienced Truckers' Advice' started by Shackdaddy, Nov 16, 2021.
  1. Shackdaddy
    Shackdaddy Medium Load Member
    331
    4,872
    Aug 5, 2021
    Where I work they started putting cameras in trucks recently. Well now the managers are po’d because they’ve found tape and vaseline on some of the cameras. Now they are putting them in all trucks and are talking smack that anyone caught tampering with them will be fired. Funny since many are getting away with lots of other things due to the driver shortage so I’m pretty sure it’s a bluff.
    So is there a better way to disable these things. Maybe a permanent marker like a sharpie on the lens ? Or would that come off with alcohol.
    I have no intention of disabling these things myself, but I have a pretty good idea on who’s doing it, so I’m just gonna make some suggestions in group talk something like whoever is doing this would be much more effective using a Sharpie as Vaseline and tape is easily removed.
    Any thoughts ?
    Anyone else seen anything like this happen with cameras.
  3. Lunatic Fringe
    Lunatic Fringe Medium Load Member
    477
    1,401
    Oct 1, 2016
    Fine-grit sandpaper on the lens works wonders.
  4. LoneRanger
    LoneRanger Road Train Member
    3,661
    9,445
    Jun 3, 2018
  5. Shackdaddy
    331
    4,872
    Aug 5, 2021
    I can see that working.
    Not as sure about that.
  6. D.Tibbitt
    140,840
    Unplug it from its power source .
    mpow66m, Coffey, Oxbow and 2 others Thank this.
  7. LoneRanger
    3,661
    9,445
    Jun 3, 2018
    I think they are hardwired. Only way is frying the electronics in the camera. But it’s most likely dual front and driver facing so. You basically need to cover it.
    D.Tibbitt Thanks this.
  8. Mototom
    Mototom Road Train Member
    1,388
    2,703
    May 7, 2019
    Quit and work somewhere else before screwing up your dac
    Or buy the security bit and point it at the floor
  9. Shackdaddy
    331
    4,872
    Aug 5, 2021
    I already have multiple job offers. One I verbally said I’d start after the first of the new year.
    Just don’t mind seeing others destroying their precious cameras which only exist
    to get the driver into trouble. I’m not gonna mess with them. But happy other are.
    CorsairFanboy and skallagrime Thank this.
  10. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,079
    Sep 24, 2019
    Raleigh, NC
    most have a power wire & fuse going to a power source.
    That being said...
    They can see if it has become disconnected. If you have signed anything regarding the cameras, then you will be on the hook for tampering with company equipment plus disabling the camera.
    If you truly want them to quit watching you or give you an approved cover for the inward facing camera, try things that won't get you fired.
    Dancing nakey during your break
    Knuckle deep nose picking
    "exercises" while on break.
    D.Tibbitt and Shackdaddy Thank this.
  11. Eddiec
    Eddiec Road Train Member
    2,191
    3,359
    Feb 2, 2015
    Buy your own truck and drive like you want before you decide to vandalize someone's else's equipment
