Best way to block push in air fitting
Discussion in 'Ask An Owner Operator' started by MTMAUS, May 1, 2024.
  1. MTMAUS
    MTMAUS Light Load Member
    222
    175
    Sep 28, 2019
    Up behind my dash, I have an unused 1/4 air fitting port, is leaking pretty bad, its apart of something bigger with 4 - 5 air lines going into it.
    It has a little 1/4 air block in it, I put a new 1/4 blocker in there, but it still leaks.
    When I get a chance I will try with some hose but I doubt it will work.
    Is there a way to block off this fitting, I was thinking some JB weld or steel cement.
    Would really like to not have to pull the whole dash out just to get this replaced.
    I know its dodge and everyone will say, do the job properly, bit in this instance I think bodgy is worth a try
    Thanks
  3. IH Truck Guy
    4,119
    46,694
    Mar 2, 2008
    Purgatory
    I would slide a piece of line in it that has the end crimped and melt it with a torch.
    Unless that is what the blocker you used is for.
  4. MTMAUS
    222
    175
    Sep 28, 2019
    I have never done that before, I am assuming I melt the line first and then jam it in?
  5. IH Truck Guy
    4,119
    46,694
    Mar 2, 2008
    Purgatory
    Ya,you don't want to create any more problems under the dash.lol
  6. Ridgeline
    22,108
    113,241
    You sure it is not a vent line that can't be blocked?
    AModelCat Thanks this.
  7. AModelCat
    154,358
    Definitely don't want to block off an exhaust line.
  8. MTMAUS
    222
    175
    Sep 28, 2019
    Nah, its not an exhuast, 100% its an unused port, thats just got a blocker in it.
  9. 86scotty
    86scotty Road Train Member
    4,375
    11,610
    Aug 27, 2017
    Appalachia
    We always called those blockers plugs.
  10. 062
    062 Road Train Member
    6,143
    33,166
    Oct 20, 2013
    Most any truck parts supplier or dealership will have push to connect line caps.
    You can also use a Tee connector and a foot of line. Hook the line to the center port, then to either end, then plug your line into the open port.
