Best way Denver to Phoenix
Discussion in 'Experienced Truckers' Advice' started by JC1971, Oct 14, 2021.
  1. JC1971
    JC1971 Road Train Member
    2,660
    9,711
    Jul 29, 2013
    L.A.
    This will be a 40K+ load. I-25/I-40 is 100 miles longer than going through southern Colorado and Wolf Creek Pass. Do you all just stay on the interstate usually?
  3. buzzarddriver
    3,566
    10,282
    Feb 1, 2011
    Dallas, TX
    I-25 south to Albuquerque, I-40 west to Flagstaff, I-17 South to Phoenix, 888 miles, Easier grades and less weather problems.
    Dave_in_AZ and JC1971 Thank this.
  4. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,860
    Apr 29, 2020
    ^^^yes^^^
  5. Dockbumper
    3,778
    9,860
    Apr 29, 2020
    You will hate yourself for the rest of your life if you take that route to save 100 miles.
  6. mustang190
    mustang190 Road Train Member
    2,846
    6,115
    Jan 18, 2011
    Florida Panhandle
    Bottom line,,there is no good way. :(
    JC1971 Thanks this.
  7. Dockbumper
    3,778
    9,860
    Apr 29, 2020
    Oops....hit send accidentally. You would hate yourself if you were empty too. Unless you want to stop and ski along the way.
  8. Dockbumper
    3,778
    9,860
    Apr 29, 2020
    Up and down Raton is what it is. After that.....40 west to 17 south is a breeze.
    JC1971 Thanks this.
  9. mothertrucker004
    mothertrucker004 Bobtail Member
    15
    9
    Oct 17, 2021
    This...I've done Wolf Creek, It's not fun...there are songs about it. Raton has maybe 5 miles of steep ( half up, half down), weigh station at the summit going south, grade out of flagstaff is easy. Fueling options are spotty in NM. There's a Loves in Pueblo, CO and another on 40 in ABQ - a few mom and pops in between, so plan those stops. You're going to waste a ton of time taking Wolf Creek, and this late in the year, you could easily get shut down due to weather.
    ETA: south side of Raton has construction, one lane and narrow. GPS might try to tell you it's closed...it's probably not, but check the DOT signs in Trinidad
  10. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    I used to take the 285 way all the time because it is just prettier than going thru Colorado Springs. They do a good job clearing it usually I never had any real bad roads thru there.
  11. Dave_in_AZ
    386,039
    Only @Opus takes WCP in the winter loaded heavy.
    Opus Thanks this.
