Best used truck for crude oil
Discussion in 'Oilfield Trucking Forum' started by greatvines, Mar 11, 2015.
  1. greatvines
    greatvines Bobtail Member
    19
    Mar 7, 2015
    I'm thinking of getting a used truck for crude oil. A little bit of off road and on road. 50 to 250 mile runs. What would be the ideal setup? I'm looking at the Kenworth T800 but maybe the T600/T700 would work as well? What year, mileage, what gear ratio, tire size, transmission, engine, air suspension, locking diff? Preferrably dependable, what are your experiences as far as the best truck for crude oil hauling? Which configuration would you look for in terms of a truck being a no-go crude hauler when looking at Ads?
  3. 2fuzy
    2fuzy Road Train Member
    1,053
    324
    Jun 19, 2008
    Granite Canon,WY
    first I will preference this with I was doing oil when oil wasn't cool
    Best truck I have found after much trial and error and a bunch of spread sheet data also this is in my application hauling tandem axle trailers is a frieghtliner classic folks will tell you I am full of buy a pete with a cat ..........here is my reason my 3 classics I have had I have been running in the patch since 2007 they have taken lees money and in up keep the the 7 KWs I have gone thru and petes just seem to fall apart but here is the main reason for them 12,400 steers 35,800 drives and 35,400 on the trailer completely legal with 185 bbls of 39 grav oil thru the WY scale the KWs were about 168 legal
    17x4.50 or $76 dollars more a trip 229 more a day 5737 more a month 68k more a year
    59halfstep Thanks this.
  4. kogaFX
    kogaFX Light Load Member
    161
    54
    Jul 19, 2013
    Frozen Lease Road, ND
    I absolutely believe you. I used to think PACCAR was the end all be all... but having driven Pete's in the patch for a while I'm convinced they are road queens not meant for oilfield duty, always something going wrong. The FL Classic is a tank, and if you go pre-2002 with a Detroit 12.7 it will be absurdly reliable.
  5. cmbks21
    cmbks21 Medium Load Member
    327
    94
    Nov 9, 2013
    +10000 on a classic
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Another one for the classic with 12.7, my uncle just can't seem to kill his
  7. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    not sure what state you thinking about running but t-800 is a good choice a lot of other good choices out there too tho i think specs matter more than brand of truck
    the biggest things i would want
    heavy spec.
    40k+ rears
    18 speed prefered 13 ok
    gears 3.73-4.10 3.55 at a absolute min if you got 550+hp with the lower gear options less hp will be fine
    if your in a greater than 80k state like nd i would want a pusher axle
    full lockers would be a big + as well
    already having a wet kit will save you about 3500 as well
  8. 2fuzy
    1,053
    324
    Jun 19, 2008
    Granite Canon,WY
    one thing to consider when it comes to state you want to run in
    The big trucks limit your available market in which to work and cost you more in overhead when times are slow and in the end I noticed the actual profit between the two is negligible
  9. DRTDEVL
    DRTDEVL Road Train Member
    1,706
    3,419
    Jan 27, 2013
    Austin, MN
    Don't count out the old FLD models, either. My last company-issued truck finally died an untimely death (N14 head cracked) at 2.4 million oilfield miles (day-cab, slip seat, 24 hour operation). The prior one died at 2.2 million (C15 lost rings, excessive blowby).
    I prefer to older trucks to the newer crap they have (2014 Volvos), and I haven't been here long enough to get a 2006 Western Star (the other good truck for this environment), so I keep my nose out for available FLDs if possible.
    Another note: FLDs are cheaper than Classic XLs.
  10. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    Western Star?
    Get one with double locking axles!
  11. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    that's the nice thing about lift axles is if they are not doing you any good no need to put them on the ground, if they are not touching the ground there not costing you money (beyond your initial investment) they will cost you about 1500lbs in increased empty weight if you happen to run somewhere that is 80k max. but will gain you about about 6500 in payload on your bridge after calculating the increased empty weight. but well worth it in my opinion if your primary area allows you increased payload for the extra axle.
