Best truck for a construction company
Discussion in 'Ask An Owner Operator' started by Cash Money, Apr 1, 2007.
  1. Cash Money
    Cash Money Bobtail Member
    29
    Vanderbilt, Pennsylvania
    What do you think is the best truck to use for a construction company? I mean for hauling materials and equipment. I've always liked a Mack for that application. What do you guys think?
  3. Alaskan
    Alaskan Light Load Member
    191
    9
    Jan 7, 2007
    Houston, Alaska
  4. Cash Money
    29
    I dont know what a Pete 378 goes for, but I forgot to mention that this would be on a very low budget.
  5. Alaskan
    191
    9
    Jan 7, 2007
    Houston, Alaska
    check out ebay...I don't know what they cost new, I am sure it real expensive...2 of the companies I have worked for used them, they are great for small and large applications. My last job had 140,000lbs + loads, and the petes held up great, including the -80 temps we regularly had.
  6. broncrider
    broncrider Road Train Member
    ive driven westernstars, kenworths, petes, internationals and frieghtliners, no i dont think make matters. of all of those that i have drove one thing is always pretty close....the specs. day cab, short wheel base, heavy axles and frames, big power motors and 13 spd's, diff and axle locks and a good driver.lol
  7. Alaskan
    191
    9
    Jan 7, 2007
    Houston, Alaska
    probably makes no difference...but petes are the way, because I say so. and thats all that matters.:biggrin_25515:
  8. Cash Money
    29
    people say that the only thing different is the cab. except macks because they make their own stuff. but I like Petes and Macks.
  9. Alaskan
    191
    9
    Jan 7, 2007
    Houston, Alaska
    if your under a tight budget, then go with whats cheap... Now I only see 18 wheelers with large construction companies, most smaller ones, drive the f-700's or your f-450's with trailers...how much material we talkin?
  10. Cash Money
    29
    John Deere 450 loaders and bulldozers, a Cat backhoe and a smaller skid steer. Stuff like that.
  11. broncrider
    just lighter stuff then....cheapest route to go would prolly be a used single screw tractor and a gooseneck tandem axle equipment trailer...it should meet all DOT specs for hualing stuff that wieghs under 26,000 lbs
