Best truck apu air conditioning?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Sea0fgreen, Jul 31, 2023.
  1. Sea0fgreen
    Sea0fgreen Light Load Member
    98
    51
    Jul 1, 2009
    Rural USA
    Most companies Ive worked for use tripac. Looking at the brochure it says the ac is 13000 something btu. Rated for 95 degrees.
    These 100+ degree days it can't keep up and I'm wondering if any of y'all have tried or used other systems. I've seen one that claims its 22000 btu but it looks a little sketchy.
  3. snicrep
    snicrep Heavy Load Member
    952
    1,722
    May 13, 2009
    mcallen, tx
    I idle until the sun goes down, then run the apu. Company truck though so fuel isnt a worry.
    hope not dumb twucker Thanks this.
  4. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    1st off I'm a 0/0 so I can do what I want to my truck...
    I have a 3,500 watt "super quiet invertor generator" on my catwalk and a 5,500 btu portable AC sitting between the seats (think R2D2) will run 12hrs on 2gl of gas..
    Last week in Arizona at 110° i was sleeping under a cover
  5. snicrep
    952
    1,722
    May 13, 2009
    mcallen, tx
    Thats good. But im a co. Driver snd i cant do what i want with the truck. But i dont ever worry about maint and fuel. I can walk away and have worries. Its too late in the game for me to own .but this was about apus, oops.
  6. hope not dumb twucker
    5,049
    44,343
    Aug 23, 2022
    Company truck has a green brand apu. Normally it’s fine. Heats cools the bunk, pretty much cools the front of can. Unless the curtains are closed then no. That’s if it doesn’t overheat. Was just in the south west. Cali nm az and it overheated durning the day. And a few nights had to run main engine. Otherwise it’s good
  7. snicrep
    952
    1,722
    May 13, 2009
    mcallen, tx
    Mine ran in those same areas witjout failing. Just wasnt good enough for comfort in the day
  8. tscottme
    tscottme Road Train Member
    Near 100F the TriPac A/C won't keep the whole truck cab cool, just the sleeper if you close the sleeper curtain. I think the biggest complaint about the Thermoking Tripac is the cost, it's expensive.
  9. hope not dumb twucker
    5,049
    44,343
    Aug 23, 2022
    I don’t know. Just had it serviced. Mechanic thinks it needs a aux fan to keep it from overheating. Or a new control board. When I had a trainer his got switched out and no problems. Company knows so it’s not on me.
  10. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,947
    3,306
    Jun 10, 2019
    What you need to do is be one step smarter than the sun. If you are parking in the evening, it sets in the west, right? Well then park facing EAST, and it will set behind you.
    I started doing this in the Dallas area and I've been cool as a cucumber ever since. I have the Tripac and it works perfect.
  11. Blagoje
    Blagoje Medium Load Member
    441
    956
    Jul 14, 2022
    Paris, Illinois
    I have been happy with my Thermo King evolution APU, more often than not on hot nights I usually have to turn it down or off.
