Best tool to thump a tire
Discussion in 'Experienced Truckers' Advice' started by HardlyWorkingNeverHome, Jun 3, 2015.
  1. HardlyWorkingNeverHome
    HardlyWorkingNeverHome Heavy Load Member
    709
    316
    Mar 18, 2008
    Hamden,CT
    I have been driving over 18 years now. I've bought just about every tire thumper over the years. Most of them just don't give you the feedback you need to decide wether you need to pull out a tire gauge or not. Also they are over priced.
    I found that a $3-$4 rubber mallet does it best. The surface area on a rubber mallet means you get a better slap on the tire without it bouncing off like a small sledge would. It also creates a better sound that you can evaluate than other types of thumpers.
    The best way to thump a tire, especially when it is cold out, is to put one hand on the tire as you thump it. The vibration you feel is an even better way to tell if a tire is under inflated.
    Save your money. Don't buy a $20 thumper. Do buy a tire gauge.
  3. truckon
    truckon Swamp Thing
    4,775
    15,915
    Dec 16, 2011
    Like I'd tell you!
    The best tire thumper is a air gauge.
  4. HardlyWorkingNeverHome
    709
    316
    Mar 18, 2008
    Hamden,CT
    You thump your tires with an air gauge?
    I know what you are saying ;)
    Most guys never even look at trailer tires never mind using a gauge.
  5. Moosetek13
    Moosetek13 Road Train Member
    14,520
    17,975
    Nov 1, 2010
    Burnsville, MN
    I use a wood thumper that is weighted at the thump end.
    It gives very good feedback.
    I think it cost around $12.
    In my last level 2 inspection the DOT guy just kicked the tires. Ya, that's even more accurate I guess.
    A gauge is best, but I don't pull it out if I get the right rebound and sound.
    It's rather funny, but with my very first mentor I did a thump test at his request.
    He said that there were 2 low tires, which he would fix after I tested them. He just wanted to see how I did with a thumper.
    I found 3 that were low, and he was surprised because he didn't catch it.
    That third tire was at around 90 PSI, while the others were closer to 80.
    A thump is good, if you know the feel and sound.
    It won't give an accurate measurement, of course. But it will let you know if a tire is TOO low.
    HardlyWorkingNeverHome Thanks this.
  6. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    I like the cat eyes the boss put on the truck
  7. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,124
    Jun 3, 2015
    I use the base of my palm to rule out extreme low air or flats. When I'm feeling bored or paranoid I'll use an air gage.
    Wheel thumpers only work for people who have that keen sense of what a 100 to 110psi tire should sound like - I don't.
  8. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    I use a small heavy sledge hammer. I also keep an eye on tire bulge.
  9. mtoo
    mtoo Road Train Member
    1,928
    4,427
    Jan 15, 2011
    Retired on bended knee
    I use one of my multi purpose tools. A 3 pound hand held sledge. In the winter I use it to smack my brake drums if frozen, it also makes a great tire thumper.
  10. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    2 1/2# sledge.....with my other palm on the tread. Over the years (all 4 of em) I've learned what 100PSI should feel/sound like. My musical ear helps imensely. Not between 98# and 100, but within 10# I can hear/feel the difference.
  11. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,521
    May 28, 2015
    I use a regular framing hammer. I generally can tell within 10# or so from the tone if the tire needs attention. The "binks" are good , the "bonks" get the gauge out. The "thunks" get me cussin'.
