Best sleeper mattress and set up for team driving?
Discussion in 'Experienced Truckers' Advice' started by steverino, Jan 6, 2019.
  1. steverino
    steverino Bobtail Member
    39
    21
    Nov 14, 2012
    I'm about to start a new job as a team driver and want to get the best sleep I can, and the trucking company I'll go with, eventually, needs to have the equipment best suited for my needs because I'm getting tired of getting crappy sleep.
    Anyone have any advice as to what provides the best sleep while driving teams?
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    What we did was put down 4 body length pillows and two sleeping bags under the matress. The pillows built a nest of sorts up top.
    When just so the whole arrangement soaks the worst of the ride on some bad roads, however you would want the crash net up because there is a risk a high bounce plus a nose down will throw you forward a little bit.
    Matresses being what they are it's never any good for sleeping unless you are sitting still.
    Lepton1 and steverino Thank this.
  4. Allow Me.
    10,642
    12,100
    May 28, 2009
    Rancho Mirage, Ca.
    Most co's use standard mattresses. Sleeping behind your co-driver can be nerve wracking. He may hit every pot hole and constantly slam on the brakes or make right turns too fast ! OR, he may have consideration for you and keep the music off, and be a smooth driver ! Good luck
    x1Heavy, CorsairFanboy and steverino Thank this.
  5. steverino
    39
    21
    Nov 14, 2012
    I know I'm a good driver for my partner and I'll expect the same be done for me. Of course, some drivers are just better than others regardless.
    x1Heavy Thanks this.
  6. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    I've run my fair share of team, in company trucks, my own truck, and my brother's truck. Your best investment would be a 2" Memory Foam mattress topper. That works wonders. It's about $80 at any Walmart.
    Lately I have been doing research on more expensive mattresses, although I rarely team anymore. The Purple mattress intrigues me.
    x1Heavy, IluvCATS and BillStep Thank this.
  7. IH Truck Guy
    4,118
    46,687
    Mar 2, 2008
    Purgatory
    Suspended bunk is the only way to go.
    Takes alot of the jarring out of the ride.
    That and having a smooth codriver.
    Lepton1 Thanks this.
  8. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    I gave some serious thought to rigging a hammock in the bottom bunk. Never followed through with it.
  9. TIMPTE 527
    TIMPTE 527 Medium Load Member
    608
    827
    May 28, 2018
    :scratch:...Hammock?
  10. IH Truck Guy
    4,118
    46,687
    Mar 2, 2008
    Purgatory
    Nope 3/4"plywood with 4 eyelet hooks on the corners .attach with
    Bungees to 4 hooks mounted in the back corners of the sleeper and 2 on the front.
    Put the mattress on the plywood and adjust the ride by how many bungees you put on each corner.
  11. TIMPTE 527
    608
    827
    May 28, 2018
    Wont work. To much swinging around.
    LoSt_AgAiN, IluvCATS and Lepton1 Thank this.
