Best Route LA to Denver
Discussion in 'Questions From New Drivers' started by SoCalKid, Jun 12, 2022.
  1. SoCalKid
    SoCalKid Bobtail Member
    31
    18
    Mar 22, 2022
    Los Angeles, CA
    Hey all you experienced drivers!
    I have a refrigerated load going from LA to Denver coming up this week. The load is pretty light for a reefer load (30k lbs). I’ve seen a lot of warnings about taking I-70 through Colorado, but it seems that most of these warnings are for every time of the year outside of summer.
    I do have some experience driving on grades, although I’m sure it doesn’t compare to Colorado. I’ve driven I-68 through Cumberland, MD at 80k lbs many times. I drove with my trainer west on I-70 in Colorado last year at 60k lbs gross, but I only drove a few miles west of Denver before my trainer took over and drove us to I-15.
    So my question is, what is my best route to get from LA to Denver given the weight of my load and the time of year? Is the direct route on I-70 best? Should I take I-80 through Wyoming and then drop down on I-25? Or am I better off going I-40 to I-25?
    bryan21384 Thanks this.
  3. SoulScream84
    3,422
    25,926
    Mar 21, 2020
    If you've pulled grades at heavier weights then 70 isn't bad. Follow the speed limit signs and you'll be fine.
  4. SoCalKid
    31
    18
    Mar 22, 2022
    Los Angeles, CA
    Awesome, thanks for the insight!
  5. drvrtech77
    drvrtech77 Road Train Member
    13,646
    132,905
    Mar 20, 2010
    This time of year isnt bad..the only thing might come across is some high winds in Utah if it’s doing its thing…
    Suspect Zero Thanks this.
  6. Capacity
    Capacity Road Train Member
    1,499
    3,116
    Jul 28, 2019
    Neenah Wi
    If you take 70 it's a beautiful ride , check out Ghost Rock in Utah.
  7. SoCalKid
    31
    18
    Mar 22, 2022
    Los Angeles, CA
    Thank you! As of right now, the forecast seems good on the day(s) I would be passing through. I know how that can change though
  8. SoCalKid
    31
    18
    Mar 22, 2022
    Los Angeles, CA
    That’s what I’ve heard. It seems at this time of year the general consensus is to take I-70. I think I’ll give it a shot
  9. Allow Me.
    10,642
    12,101
    May 28, 2009
    Rancho Mirage, Ca.
    30K isn't that light a load, considering 44K is a normal heavy load. What is the condition of your truck/trailer ? And will you give it a good pre-trip ?
  10. Numb
    Numb Crusty Curmudgeon
    3,938
    8,760
    Jan 30, 2012
    Charlotte, N.Carolina
    thought he meant Louisiana at first. lol
  11. SoCalKid
    31
    18
    Mar 22, 2022
    Los Angeles, CA
    Truck and trailer just recently received inspections and had all issues corrected. So as far as I know, they should be in good shape. And yes, most definitely will be doing a thorough pre-trip!
    Speedy356 Thanks this.
