who makes the best rain pants?
I've had two sets of the 20 mil pvc rain pants from tractor supply and I keep ripping the legs when I get in/out of tractor.
I need a set of industrial grade rain gear and I don't mind paying for something that will last more than one use.
Any recommendations?
Best rain pants / rain gear
Discussion in 'Oilfield Trucking Forum' started by tde66, May 13, 2015.
Carhartt. Hands down. Although, they are on the expensive side.
bullhaulerswife Thanks this. -
Stay as far away from that plastic #### as you can. It's heavy and makes you sweat, assuming you actually need to do some work. Carhartt is good stuff, but any Cabela's or Bass Pro Shops will have the good, breathable type (Gore-Tex being the most expensive). But alas, as in most things, quality costs.
Army surplus stores will have good ones too.
my brother gave me some called frogtoggs a couple years ago. was skeptical when he gave them to me they're very light and thin material. not sure of the cost but best raingear I've ever had. not cumbersome, very durable and keep you dry as dirt. wicks away moisture from inside as well. use them riding the bike all the time as well and stay pretty dry even in that environment and type of use.
Lepton1 and bullhaulerswife Thank this. -
Don't forget that your rain gear needs to be FR rated...
JPenn Thanks this. -
Froggtoggs or gortex USGI jacket and pants
Thanks to all who replied.
I'm headed to Cabelas to check out the gore tex stuff. it has to be better than the crap from tractor supply -
Outer layer FR, unless you're not required to be wearing FR. Don't cheap out on it. My Tingley FR trench raincoat cost $65. There are some down as low as $25 locally. -
Frogtoggs have brought the original concept of the trilaminate waterproof breathable outerwear back... with a wonderful twist. The outer fabric layer is nonwoven, MUCH stronger and more tear resistant than woven fabric. It's also cheaper.
I use mine for chaining or working in muddy conditions. They dry fast and are easy to wash.
You can find them in the outdoor products area at Walmart, in the camping section.
