Best quality lightweight dry van brand & model
Discussion in 'Experienced Truckers' Advice' started by KB3MMX, Jun 5, 2015.
  1. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Hello all,
    Looking at buying a trailer and looking for suggestions based on experience.
    Currently running a 10yr old Great Dane dry van w/ hendrickson air ride and air slider. It also has etrack, kemlite roof, plastic rub rail, wood floor and heavy steel wheels with traditional duals. It has NO aero enhancements currently.
    My lightweight combined is 34,400 and looking to further reduce weight and increase payload capability and fuel efficiency.
    I've been happy with the Great Dane but looking at the Utility 4000 series and they look very nice.
    Any suggestions on options or other brands?
    THANKS !!
  3. 88 Alpha
    88 Alpha Trucker Forum STAFF Staff Member
    5,574
    18,061
    May 12, 2012
    SouthEast Alabama
    I'm not sure of the model, but we run Hyundai trailers and haul heavy for a dry van. I can scale 48,800. Empty weight is 31180. Aero is a fiberglass-type skirt and wide singles.
    Your 780 Volvo is going to make a difference. We saved about 2000#s when we switched from the Volvo to our current tractor.
  4. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    We have a mixed trailer fleet with Wabash, great Dane and Utility and I can't say one is better than the other. Unless your trailer is in bad shape. I would just save money and keep it
  5. 88 Alpha
    5,574
    18,061
    May 12, 2012
    SouthEast Alabama
    This is good advice. At least with KB3's 10 year old trailer, he knows how it will hold up over time. Our lightweight Hyundais flex a lot, so it makes me wonder about the longevity of those trailers. For a savings of just a couple thousand pounds, probably better off to keep his, unless some customers want him to have a trailer 10 years old or newer and he is getting prepared for that last year.
  6. PackRatTDI
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    The only places I've ever had trailer age come up were paper mills who load those heavy rolls on the floor. Otherwise it's never come up. So I figure unless he loads a lot of paper mill loads, I wouldn't worry about the age.
  7. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    I just bought a new Hyundai HT Composite and am a little disappointed. The coating on the interior plate walls is little more than paint so it scuffs easily (after 2 months the walls look almost as bad as the 18-year old Monon it replaced). One of the slots in the logistics posts deformed just from me cranking on a ratchet strap -- I'd hate to see it after an accident. And it came with Hendrickson Vantraax suspension which I later learned are known for alignment woes (you can easily spot vantraax suspension from the larger axle tubes).
    On the other hand, it came with Havco composite flooring & side skirts for ~$1500 less than a bare bones US-built trailer. Weighs 13,980 with steel duals & skirts.
  8. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    I've also had it come up with chemical totes, copper, auto parts, and a handful of union warehouses in the northeast.
    PackRatTDI Thanks this.
  9. PackRatTDI
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    So I would say if a lot of your customers ask about trailer age, it might be worth it to invest in a newer trailer. Otherwise don't worry.
    double yellow Thanks this.
  10. KB3MMX
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Ok thanks for the replies so far guys!
    I'm also considering the conversion to wide base singles on aluminum rims and adding aero enhancements to the old trailer. However, I'm worried about spending that much on a old trailer to begin with.
  11. KB3MMX
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    As far as new trailers, I'm thinking Hyundai might be out because of cheaper quality.
