Best portable air conditioner for the truck?
Discussion in 'Ask An Owner Operator' started by Dino soar, Mar 12, 2022.
  1. Dino soar
    Dino soar Road Train Member
    4,779
    26,639
    Dec 8, 2017
    The generator has really been great combined with the space heater. I've been very warm all winter without idling my truck.
    Before you know it we're going to be in the warmer weather.
    What is the correct BTUs that you would need? I understand that if you have an air conditioner that is too large it's not good just like having one too small.
    I also have seen some that say they are self evaporating so that you don't have to worry about drainage.
    Any recommendations on the best portable air conditioner unit for the truck?
    Boondock Thanks this.
  3. Rideandrepair
    17,176
    55,740
    Aug 8, 2015
    I tried a portable. It was 8000 btu. Largest that my 2000w generator would run. It was almost useless. Worked OK at night. It was a single hose model. Supposedly the dual hose models work better. Either way, it wasn’t efficient. Portables draw more amps than standard units. It also was a self evaporating. Nice idea, but didn’t work. It would get full of water and shut down, or leak water everywhere. To make matters worse, it quit anytime it wasn’t perfectly level. We used it while driving, one weekend. It would quit, and I’d rock it back and forth spilling water everywhere, till it started again. Lol. It was crazy. Big waste of money. It’s sitting here at the house. Needs to be in the trash. I advise a 500 or 600btu window unit, putting it in the passengers window when needed. Or get a small mini split set up. There’s some good options. available.
  4. 062
    062 Road Train Member
    6,128
    33,094
    Oct 20, 2013
    Don’t believe the “no drain” claim. I bought a 12k btu a few years ago when the ac went out at the house. The one I have will blow the water back into the house and makes it hard for the unit to cool.
    I rigged it up to drain into a container and would have 2.5-3 gallons of water in 8hrs.
    It dropped the output air temp about 10-12 degrees.
    Dino soar, Boondock and Rideandrepair Thank this.
  5. Dino soar
    4,779
    26,639
    Dec 8, 2017
    I've been reading more about the self evaporating and they say if you use it in a dry climate you may not get much water but in a humid climate you will have water.
    I really did not want to get a window unit because then I have to keep putting it in the window and taking it out.
    Can't I buy an electric motor to run my compressor and disconnect it from the engine, and then just run my blower motor off of the generator?
  6. loudtom
    loudtom Road Train Member
    1,717
    2,799
    Aug 26, 2016
    I'd recommend a mini split as well. They can heat and cool, and use very little energy. The one I have will never cause the generator to surge, even on startup. I believe I have a 9000 BTU unit. The only issues are going to be having the space to mount the indoor and outdoor units, and making sure the indoor unit can properly drain. I never had an issue with the first unit leaking. The new one I set up perpendicular with the truck instead of parallel, and when the truck leaned sideways significantly it leaked. I adjusted it after the first time it leaked and it hasn't done it since.
    I have not been able to test it in like 120F heat, but it stayed cool all summer without pulling any curtains, even in Florida. It says it can heat down to 7F, but I think it starts losing its effectiveness around 30F or so.
    RubyEagle and Dino soar Thank this.
  7. Dino soar
    4,779
    26,639
    Dec 8, 2017
    Do you have to cut a hole in the truck somewhere for that system?
  8. loudtom
    1,717
    2,799
    Aug 26, 2016
    Yeah, maybe 2.5" diameter, run the lines through a plastic bulkhead, spray foam to seal it. My drain line runs through my sink, but it could probably run through the same hole as the piping. Just replace the flimsy plastic hose with irrigation tubing.
  9. Dino soar
    4,779
    26,639
    Dec 8, 2017
    Small hole or holes for the Lines is no big deal.
    Is there a particular manufacturer or type of Mini Split to use?
  10. loudtom
    1,717
    2,799
    Aug 26, 2016
    I've used Pioneer units. The outdoor unit might need reinforcement, like a ratchet strap or bracket over the top to keep it from vibrating. The thin metal where it normally mounts to a concrete pad can break at the welds since it's designed to be stationary. The good thing about these units is that they are precharged, so you can set it up and don't need to pull a vacuum or charge them.
    bumper Jack and Dino soar Thank this.
  11. Dino soar
    4,779
    26,639
    Dec 8, 2017
    I took a quick look on the Home Depot site and some of them have heat pumps for heating.
    That is a very interesting idea.
    bumper Jack Thanks this.
