Best portable AC no Apu
Discussion in 'Ask An Owner Operator' started by dztruck, May 9, 2021.
  1. dztruck
    dztruck Light Load Member
    271
    208
    Feb 22, 2017
    Hey guys, any products u guys use to stay cool in the summer? I don’t have an APU and im in the southwest and its freakin hot at night. I do not want to run the engine. Any good products you guys know of that have gotten you through the hot summer nights? Ive seen portable AC units on amazon, any idea how good those are? I have a 6000w pure sine wave inverter. Thanks!
  3. Concorde
    Concorde Road Train Member
    4,344
    15,419
    Jun 29, 2016
    West Melbourne Florida
    Big bowl of ice and a 12v fan :)
  4. dztruck
    271
    208
    Feb 22, 2017
    Ive seen some of the fans on amazon that lets you put ice into them. Do those really work? My fridge can freeze water for sure.
  5. Arctic_fox
    3,861
    19,402
    Sep 16, 2016
    All portable ACs are gimmicy crap not worth the money. They rarely work, never last and dont cool well. Any that WOULD work are as likely as not to drain your battery to death overnight.
    However, you have options. For example a good 12 volt fan helps. Soak a shirt in water, wring it out and use a fan on low and you will be cool for a couple hours. There are cooling blankets that use a mix of materials to better pull heat. Some that will circulate water to help cool you. There are gel pads that help pull heat away. And there are of course classic large fans.
    I have also seen people use standing AC units and a mini honda gas generator in older trucks that seem to work ok. I have also seen stuff like these Truck Air Conditioners start to become popular from some owner ops.
  6. dztruck
    271
    208
    Feb 22, 2017
    Maybe i can run my fridge on the coldest setting and leave the fridge door open with a 12v fan with ice water. #### i hate the heat. I can sleep when its cold but can’t sleep at all when its hot
  7. slow.rider
    slow.rider Road Train Member
    2,005
    4,740
    Apr 4, 2017
    NYC
    Won't work very well. A fridge generates cold by removing heat. The heat is pulled out and ejected thru the coils, and the coils are also in the cab. Plus more heat is generated by the machinery operating. So for every x amount of coldness in the cab, you're also creating x+y amount of heat in the cab. That's why window air conditioners work so much better. The coils are outside so the heat goes outside.
  8. God prefers Diesels
    4,198
    22,258
    Jun 26, 2020
    South Texas
    I run a window unit and a Honda generator. If you try to run an A/C off your inverter, your truck won't start in the morning. A cooler full of ice has about 600 btu total. A small A/C is about 6,000 btu per hour.
    You can get a Predator generator and a small A/C for less than a grand.
  9. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    Do a search on this forum. There were several detailed threads discussing this and showing many different options.
    Without an APU it seems most use a portable generator with a window or stand up AC unit.
  10. rachi
    rachi Road Train Member
    4,246
    5,228
    Feb 25, 2010
    SoCal
    Do you carry a 5 gal container of gas for the generator? If so, does the scale house ever give you a hard time?
  11. 77fib77
    77fib77 Road Train Member
    10,167
    62,744
    Jul 7, 2010
    St Louis
    Jarhed1964 and dztruck Thank this.
