Best onboard impact wrench
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jerseycowboy, Jul 16, 2011.
  1. jerseycowboy
    jerseycowboy Bobtail Member
    47
    12
    Dec 30, 2009
    Fort Worth
    I read all the blogs on tools, and I guess everyone has there opinion,, but I wanted to here from those who have tested the tools out so I can get a better idea on if they work the best... I'm wanting to use my air tanks off the truck to break the lug nuts and change out the breaks to save me some money. I seen one guy say he had a super duty 1/2 that worked real well, but did not say it worked real well on the lug nuts... he said it had 1200 torque,, others use the 3/4 and some 1 " I'm leaning to the 1/2 super duty with 1200 loosing torque from northern tool.. and a 3/8th hose or 1/2 if I have to,, I just need to be able to work on my truck on the road or at home,,, I can always get a 30-60 gallon compressor to use later,,
    Im looking for those who have used any of the above to give me some feed back... on what works good for them,,,,, I have a Mack truck with some nice sized tanks could be about 20 gallon I suppose... I have a air supply coupling ready on the tanks for a hose.. Thanks for your imput.... Jersycowboy
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    1/2" with 1200 ft lbs would work well. Anything 1000 ft lbs or better would work good on big truck lug nuts. The only problem is you would have to take it slow for your air compressor and tanks to keep up with repeated use. So a 1/2" would be a good choice because of the lower scfm compared to the big boys. You can find alot of good deals on air tools at pawn shops. It seems like everyone pawns air tools. If you never dealt with pawn shops, always ask their bottom dollar and you can get the marked priced knocked way down. I like Northern Tool also.
  4. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    I use 1" IR impact wrench with a 1/2 hose. It works very well. 3/8 hose restricts air flow and your tool is not going to work properly. Make sure you use a right size quick connector at your air tank so there is no air flow restriction there.
  5. jesterx
    jesterx Bobtail Member
    7
    Wisconsin
    I wouldnt use anything less than a 3/4 drive impact. 1/2 hose preferrably but you can use 3/8 if absolutely necessary. Dont mess around and try to shortcut though. I have seen a couple sets of duals come off already and dont care to see anymore
  6. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    You need an impact that uses the least amount of air in volume with the highest torque rating possible. I use an Ingersoll Rand 2141 3/4" drive
    This impact wrench uses a small volume of air(CFM) for the breaking strength it has in reverse. If you plan on using your air supply on the truck, you'll also need to buy 1/2" diameter air hose to supply enough volume(CFM) at the gun to have the driving force to remove lug nuts. You'll have to have a 1/2" fitting in the tanks to hook the hose up to. The gun I listed has a titanium impeller for the extra torque strength and low air volume usage...........it's not a cheap gun, try tooltopia.com for the best price on it.
    If you purchase a cheaper gun with a standard impeller, it will use more air in volume and may not work well doing lug nuts while using the truck for an air source.
    http://www.tooltopia.com/ingersoll-rand-2141.aspx
    25(2)+2 and heavyhaulerss Thank this.
  7. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
