Best oil for cummins isx
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Vivaspin, Nov 15, 2020.
  1. Vivaspin
    Vivaspin Bobtail Member
    27
    8
    Oct 2, 2020
    I have been doing my own oil changes and have been using shell rotella t5 15w40
    with every oil change i add about 2 gallons of lucas oil stabilizer.
    2010 prostar, 900k miles, deleted.
    what do u guys think is the best oil at this amount of miles and what should be the interval?
    truckdriver31 Thanks this.
  3. slow pok
    slow pok Light Load Member
    144
    211
    Oct 27, 2013
    lizela ga
    Wasting your money with lucus do the math for a mil miles
    truckdriver31 and I glide 47 Thank this.
  4. Vivaspin
    27
    8
    Oct 2, 2020
    $20 extra every oil change, every 17k miles. Hardly a waste of money lol
    snowman1980, flood and truckdriver31 Thank this.
  5. Lazer
    Lazer Road Train Member
    1,728
    2,725
    Jan 22, 2017
    Mobil Delvac 1300 15-40, aim for 15,000 miles
  6. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Do you have two patches put in all your new tires, if not why do you stabilize new oils? Skip the Lucas.!
    Diesel Dave and truckdriver31 Thank this.
  7. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    so you got a engine that burns oil and will need a inframe soon. just keep doing what your doing
  8. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    he has too or the engine will burn more oil. his engine is worn out
  9. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    I switched to Delo, was running Rotella. I burn less oil with the delo
    D.Tibbitt and I glide 47 Thank this.
  10. Vivaspin
    27
    8
    Oct 2, 2020
    Ok i will put away the lucas. Trucj has had inframe at 650k miles.
  11. bad-luck
    bad-luck Road Train Member
    3,247
    5,945
    Nov 16, 2013
    Baltimore, Maryland
    Just my opinion, but I never use Lucas. Reason being, is if you have ever see the internal engine parts after the engine has been torn down. All the parts are sticky from Lucas and you can feel the dirt that is stuck to it.
    If you see the internal parts when just oil was used, they are clean.
    Concorde, Shawn2130, D.Tibbitt and 2 others Thank this.
