Best new APU for the money?
Discussion in 'Ask An Owner Operator' started by Farmerbob1, Feb 1, 2019.
  1. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,791
    Jan 17, 2017
    Looking into APU's. Would prefer to buy new, with a good warrantee.
    Was just quoted 12k for a Tripac unit with Espar heater, installed, cash price.
    If fuel is 3.00 per gallon and the unit saves me 5 gallons per night, on average, including 34's, then it will take 800 days to pay for itself. If it runs for 5 hours a night on average, it will pay for itself in 4000 engine hours in those 800 nights.
    However, I do not know what maintenance costs to expect over time.
    Anyone got some real world numbers to throw at me?
    My truck is an opti-idle truck. I have enough frame space to fit a 2 foot APU box if I remove the chain rack. My chains are stored in front of the passenger seat.
  3. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    The units aren't trouble free.
    We had some used trucks leased for awhile so equipped and they took work on nearly all of them to get them going, including the heaters. It was ongoing, not very reliable, these trucks came in with 350 k on them, not that old.
    If your opti idle works, it's better than nothing, you aren't going to gain as much as someone with no idle solution installed.
    Tug Toy and Farmerbob1 Thank this.
  4. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    The numbers they (the dealers) give are crap when it comes to fuel use.
    They say .2 gl per hr..... BS it's real world .4-.5.. my volvo d12 uses .6 so it doesn't save that much. .
    Farmerbob1 Thanks this.
  5. TIMPTE 527
    TIMPTE 527 Medium Load Member
    608
    827
    May 28, 2018
    I would NEVER spend 12K on an APU. I have one because I waited and found a used truck with a "factory" installed APU. Let the OEM take the depreciation hit. I've got an APU and didn't cost me anything OOP. Maintenance is about $1000/year w/13500 hrs. on it CARRIER. BTW when I say it "costs" me $1000/year that's max. and that does not figure the savings from the truck engine not idling.
  6. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    Build a frame and put one of those small generators in there.
    https://www.harborfreight.com/2000-watt-super-quiet-inverter-generator-62523.html
    Buy a small AC unit and find a way to seal your duct work.
    https://www.walmart.com/ip/Gree-3-I...oner-115-Volt-6-000-BTU-GRPE06SHR4W/877714087
    If you want heat, use a bunk heater or buy a small space heater.
    If you have the time and inclination or Youtube/Google, you can rig together a setup for under $1000 that accomplishes the same thing. You can also get the extended warranty on the generator, or worst case scenario, another $500.
    There are some drawbacks. You have to use and carry gas. You have to stop for fuel anyway, and they sell gas there also unless you fuel at terminals. But gas is cheaper than diesel, and these generators are extremely efficient.
    If you need more power, you can get a larger generator provided you have the space. If you need more cooling, you can get a larger AC unit.
    Buy some autosocks instead of chains, and store them wherever you want.
  7. TIMPTE 527
    608
    827
    May 28, 2018
    Don't do this! These guys take the cheap way and pollute the truck stops with GASOLINE fumes and 10X the noise with their "homemade lawnmower" type apu.
  8. loudtom
    1,717
    2,800
    Aug 26, 2016
    In my experience, the diesel APUs tend to smell worse, smoke more, and are louder. The generator I linked is CARB compliant and quiet.
  9. TIMPTE 527
    608
    827
    May 28, 2018
  10. TIMPTE 527
    608
    827
    May 28, 2018
    BTW. Do you ever notice the guys that run the "homemade" APU are Mercer/Landstar O/O from Pa. or RI. with an RGN
  11. loudtom
    1,717
    2,800
    Aug 26, 2016
    That's great and all, but the setup that I linked is probably quieter, cleaner, and saves more money. I get that there are people doing the cheaper and louder generators, but that's no reason to say not to take my advice. I'm not saying grab any old generator from your shed and go to town.
    I parked next to a Prime truck in Cheyenne a few nights ago with a Tripac that was obnoxiously loud and stunk. What is the significance of that?
