best handling truck?
Discussion in 'Ask An Owner Operator' started by sharpshooter, Dec 14, 2010.
  1. sharpshooter
    sharpshooter Medium Load Member
    384
    113
    Jun 20, 2010
    NC
    Just curious what you think is the best handling trucks out there. My experience is mostly with Volvo's and Freightliners. I'm wondering about KW's and Pete's. What the different AG suspension numbers mean etc. It looks to me like the "large cars" handle pretty darn good
  3. robbiehorn
    robbiehorn Light Load Member
    143
    56
    Jul 18, 2010
    Axtell,Texas
    I'll get something started here I bet but, I sure like the way my Freightliner Columbia rides & drives.
  4. rocknroll nik
    rocknroll nik High Risk Load Member
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    Never have driven a large car...but I personally liked my KW t-600. It turned just about as tight as a century but felt sturdier. I'm not very good at the mechanics end so I can't help you with the ratio numbers and what all that means. Sorry. I'm sure one of the more knowledgeable members will pop in here. I've driven Cornbinders and Fr8shakers, and my T-6. People call t-6's an anteater but personally I think the look more like a praying mantis
    orion3814 Thanks this.
  5. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    Problem is there are so many different setups wheel base and suspension load capacity double frames.
    The ones that are the best on the open road, suck in town. So it's all a compromise, there ain't one truck that is the best at everything.
    I'll guess that the best handling is a flat top extended wheelbase with rack and pinion steering and air bags all the way around.
  6. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    Any tractor with a lower center of gravity will corner better... that leaves out the condos.
    I like Peterbilt's Low Air Leaf the best but the Pete Air Leaf and Air Trac's have been pretty good, too. I don't have much seat time with the Flex-Air but it felt pretty good in the 386 I drove for a day.
    I'll take a good handling truck over one with a short wheel cut any day... you always hear guys bragging about how easy their FL/Volvo/Farmall is to park but I may only spend two minutes each day parking but 18 hours in the saddle...
    Don't forget wheelbase has a lot to do with foul weather stability... a longer WB makes the truck react slower to adverse road conditions... pretty handy in snow and ice. You can have those 212" WB fleet jobs...
  7. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    Well i've owned 3 freightliner flds with 232wb and thought they drove and handled good untill i bought my 1st pete 379 with a 260wb with air leaf and it rode way better than the fld's then i got another with a 265 and air trac and rode ok now my 3rd pete has a 280wb with flex air and it rides like a dream, the best handleing truck i've owned.
  8. sharpshooter
    384
    113
    Jun 20, 2010
    NC
    thanks for the replies. I'm leaning toward a 379, or a w900. This vovlo does kinda wear ya out after 600+ of hills and curves. It has that top heavy sway. I'm just worried bout fuel. I don't plan on gettin rich saving fuel, I'd just like to get 6 atleast drivin nice and between 30-40 in the wagon. I'd really like to pull something when I take one for a test drive
  9. Hanadarko
    Hanadarko Independent Owner/Operator
    2,962
    927
    Oct 1, 2009
    Midwest
  10. sharpshooter
    384
    113
    Jun 20, 2010
    NC
  11. rbht
    888
    525
    Jan 23, 2010
    CT,NH
    My pete has a 550 cat with some modes and an 18spd with 3.36's and i pull a flat in the northeast at gross 90% of the time when loaded and get between 5.8 to 6.2mpg evry quater and i'am not light on the pedal.
