Best flatbed companies to lease on
Discussion in 'Ask An Owner Operator' started by mitmaks, Aug 22, 2017.
  1. mitmaks
    mitmaks Road Train Member
    2,543
    2,065
    May 16, 2014
    Whats good flatbed company I could lease onto, paying ~$2.00+ to the truck?
    Current company has cheap freight or no freight at all. Currently sitting in Little Rock AR and they cant get me load out of there here. Thet expect me to bounce as far as Oklahoma City.
  3. spyder7723
    spyder7723 Road Train Member
    15,467
    25,010
    Mar 31, 2013
    sarasota, fl
    Why the heck would you bounce to okc? Memphis is much closer and is a great market for a flatbed.
  4. mitmaks
    2,543
    2,065
    May 16, 2014
    Apparently not what my carrier thinks...
    Called me with loads from Oklahoma and Texas off of CHR loadboard. Basically garbage that noone else took so far.
  5. MM71
    MM71 Heavy Load Member
    758
    987
    Jun 28, 2008
    AZ
    Where is home? What lanes do you prefer running? Do you have experience with anything specialized? You running a newer truck? Trailer?
  6. spyder7723
    15,467
    25,010
    Mar 31, 2013
    sarasota, fl
    If youre getting screwed that bad. Id look into mercer, landstar, bennett, and admiral merchant. Maybe sammons.
    TallJoe, Hurst and QuietStorm Thank this.
  7. Roadawg
    Roadawg Light Load Member
    80
    32
    Feb 15, 2015
    One where you can negotiate your own rate off of the spot market.
    TallJoe, brar and QuietStorm Thank this.
  8. brar
    brar Light Load Member
    126
    17
    Apr 5, 2011
    CA
    Which load board do you use?
  9. mitmaks
    2,543
    2,065
    May 16, 2014
    Im in Spokane WA. Typically stay out 4-6to weeks at time. I do own 2013 KW, no trailer yet. I run all 48 states and Canada, depending on freight.
    Traveling Jones Thanks this.
  10. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Your carrier sucks then, Little Rock has always been an easy pace for me to get out of. Its like Nashville, Omaha, Newark, Phili, Memphis, Birmingham, Houston, Lexington, Atlanta, Cleveland,.. all easy in, easy out for open deck with lots and lots of $2+ mi loads. Thats just the posted loadboard junk.
    Right now its almost the end of the month in Aug. I've noticed a little bit of a slow down the freight I've been moving since March. Time to switch it up a bit,.. be versatile. Some very good paying over weight loads out of NJ to Houston area right now. $780 in permits and still netting over $3 mi after fuel.
    Find a carrier in which you can find and book your own loads. It took me a while,.. but I have developed a strategy in which I am dealing directly with brokers who have loads going to places that I have other brokers who have loads that are going places to where I have some other brokers,.. so on and so on. Phone calls,.. lots and lots of phone calls. Cant be bashful in this business.
    Good luck brother.
    Hurst
  11. Roadawg
    80
    32
    Feb 15, 2015
    That one is DAT power.
