Best choice: cat c-13 or Volvo d13?
Discussion in 'Ask An Owner Operator' started by T-Booz, Jun 13, 2016.
  1. T-Booz
    T-Booz Bobtail Member
    17
    Aug 4, 2011
    Lafayette, LA
    Hello all! I considering a move to another company, Miller, that offers a purchase plan on a used rig. After research here, I see lots of differing opinions. So here goes:
    1. 2011 KW T660, with a Cat C-13, 485hp 10sp and 450k+ miles.
    2. 2013 Volvo 630 with a D13, 500hp, 10sp with 530k+ miles.
    3. Neither, stay put!
    Currently in a Q/C lease 2014 Cascadia 350k miles, no APU. I'll be pulling tanks east of the Rockies. Not sure about the KW but the Volvo is a DEF system. Both have APU. I eagerly await all your wisdom! Thank you!
  3. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,124
    Jun 3, 2015
    #2 if less than $40k and no prior def issues. And if I were buying, id want to pay it off or trade after two/three years of hard work.
    T-Booz Thanks this.
  4. kw550cat
    kw550cat Medium Load Member
    663
    596
    May 22, 2012
    brooklyn, new york
    Unless the kw has been "fixed" I'd stay far away from an emissions Cat, so that leaves the Volvo. As mentioned, try and obtain servic records on the truck or get the ecm checked to check if/any faults that the truck had. You may be able to ontain service recirds if it was a fleet truck from the prior fllet ", or potentially by the vin by calling Volvo directly.
    T-Booz Thanks this.
  5. Dave_in_AZ
    370,743
  6. truckthatpassesyouby
    1,876
    6,124
    Jun 3, 2015
  7. Dave_in_AZ
    370,743
    No. It was unloading at the DC I work at. It's a 780. Looks even better from the sides.
    This was mine. D13 all the way baby.
    T-Booz and truckthatpassesyouby Thank this.
  8. T-Booz
    17
    Aug 4, 2011
    Lafayette, LA
  9. T-Booz
    17
    Aug 4, 2011
    Lafayette, LA
    By "fixed" you mean dpf deleted?
  10. Dave_in_AZ
    370,743
    I had 0 problems with my D13.
    I driven two cat motors. One had like 500K in a KW660 and wouldn't pull that long grade going up 15 from Vegas to Southern California, had to stop and shut down let it cool off about 2 miles from the summit.
    The other was in a mixer I drove, that was a high winding, fuel slurping, no torque motor. By the same token the mixers with Cummins engines, you tapped the throttle, and you were off and running.
    Cat parts & service are the most expensive for everything. I think 25 or 30 years ago, yea, but 25 or 30 years ago I also had no problem getting some really hot women.
    T-Booz Thanks this.
  11. kw550cat
    663
    596
    May 22, 2012
    brooklyn, new york
    Yes. But that also opens a new can of worms, so the Volvo maybe better. (Or keep looking)
    T-Booz Thanks this.
