Best CB?
Discussion in 'CB Radio Forum' started by EvilGenius, Oct 23, 2021.
  1. EvilGenius
    EvilGenius Bobtail Member
    18
    7
    Mar 12, 2020
    What is the best radio out there, and why? My 29 is finally on its way out after 15 years.
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    I like my Ranger, but spendy. Uniden pc78
    Is a good one not sure if they make it anymore?.
    Had the Uniden for almost 25 years
    Strykers make a good radio
  4. slim shady
    slim shady Road Train Member
    3,468
    14,689
    Sep 14, 2011
    Chicago, Il.
    Pretty happy with my President Mckinley. Straight out of the box with the stock mic. And a 5,' Firestik.
    Sat in garage for 3 yrs before I recently installed it. I think it was around $150.
  5. craig_sez
    craig_sez Road Train Member
    5,564
    2,709
    Sep 5, 2013
    novascotia,Canada
    You can talk to 10 different drivers and 10 different techs and get 37 different answers..
    Best bet is to look at different radios and see what you like the looks of and narrow down the list based on google searchs for options,cost and then reviews..
    I love my strykers but the next loves his galaxys and someone else gets all he needs n wants out of a pawn shop uniden or cobra..
    weasel, D.Tibbitt and Diesel Dave Thank this.
  6. Timin770
    Timin770 Road Train Member
    1,657
    1,757
    May 27, 2011
    Canton, GA
    Anytone AT-6666. Your search is over
  7. Night Stalker10
    Night Stalker10 Road Train Member
    1,667
    1,242
    Jun 26, 2017
    Ah, the best cb radio question. Well for starters, I would suggest you stay away from the import radios like Stryker. If you would like to know why, just look at the thread called "I hear hard drive". Another reason to stay away from import radios is that they are made for 10/12 meters, and cb is in the 11 meter band. What this means is that you will have to pay a tech to convert the already high priced radio to use on 11 meters, which usually isn't too hard to do. But you will have to pay the tech to do an alignment on the radio for 11 meters. So if you have deep pockets, then maybe that's the way to go.
    But since you are using a real cb radio like the Cobra 29, then I would suggest you stay away from the new Cobra radios, because they have cold solder joint
    issues (like Galaxy) due to poor quality control from the factory. If you really like the Cobra 29, then I would suggest you get the President PC78LTX, it looks like the 29, but it has the high/cut switch that a lot of guys like. PC78LTX - Uniden CB Radio
    Two other great President radios I would recommend are the Walker II FCC and the Taylor. They both have the high/cut feature as well as weather and a USB port. The Walker II FCC also has an RF power knob which is great if you want to run a small amp like the RM Italy KL203P. No need to pay a tech extra $$ to install variable RF power. WALKER II - President 40 Channel CB Radio with ASC, Scan, Roger, Weather and More
    Now these are AM radios like the Cobra 29 that you now have, but if you are interested in SSB, then the President Mckinley would probably be the best way to go. I've heard good reports on this radio. MCKINLEY - President Deluxe AM/SSB CB Radio
    I would stay away from the Uniden BC980SSB. It seems like after about a year, guys are having problems with the display going dim. Maybe this has been fixed with the newer 980's? Hope this helps.
    Matt1924 and shooter19802003 Thank this.
  8. Timin770
    1,657
    1,757
    May 27, 2011
    Canton, GA
    "....you will have to pay a tech to convert the already high priced radio to use on 11 meters..."
    It's just a couple buttons to push on the Anytone AT-6666. A child could do it
    rabbiporkchop and jdchet Thank this.
  9. Night Stalker10
    1,667
    1,242
    Jun 26, 2017
    Yup, that's why I included the words "which usually isn't too hard to do".
  10. Timin770
    1,657
    1,757
    May 27, 2011
    Canton, GA
    Prefaced by "have to pay a tech"
  11. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    all radios have a lifespan of xx number of years. constant shaking, vibration, dust, out of tune antennas, are among a few things that shorten the life. then there are the internal parts, that can only take so much heat for the hours of operation.
    the best cb radio, is one that is new, out of the box, untouched by any tech to peak it.
    oh yeah, and on sale too........
    handlebar, Timin770 and rabbiporkchop Thank this.
