Best cat engine to purchase in used semi?
Discussion in 'Ask An Owner Operator' started by Trucknlyfe, Nov 12, 2017.
  1. Trucknlyfe
    Trucknlyfe Bobtail Member
    46
    Nov 12, 2017
    I'm looking to buy another used semi here soon and I'm most comfortable with anything with a Cummings isx however I have been running across many trucks with c-12, c-13, c-15, 6nz, (3406b, 3406e) although with the 3406 engines I haven't heard anything good so I'll probably pass on those but what about the c12 thru c15 are they good engines I'm looking for a reliable cat engine along the lines of the cumming isx. (Decent fuel mileage, power and reliability) please help I don't want to ignorantly pass on a good cat engine?
  3. Pup97
    Pup97 Light Load Member
    191
    263
    May 30, 2016
    I am happy with my 3406B. Get 6.5 mpg constantly. Cheap to work on and NO ELECTRONICS that's what I like about it!
  4. Trucknlyfe
    46
    Nov 12, 2017
    Ok, thanks sir
  5. stayinback
    stayinback Road Train Member
    3,911
    8,255
    Jan 24, 2014
    chicago,il
    I had a 3406 b early in my career- Great motor 350hp and never let me down
    I Currently run a c-12 @430 hp- Do an overhead every other year- swap out a water pump or 2 and she'll be good to ya
    PacManTrap and Trucknlyfe Thank this.
  6. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    Old 1693TA,best Cat IMHO.Probably aren't many around anymore.
    Diesel Dave, 7-UP, shogun and 3 others Thank this.
  7. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    3406B was as good as a truck engine gets. The only Cat engine i ever knew to be a problem child were the 3406C PEEC engines. A C with a full mechanical pump would be good if you found one, but the ones with an electronic governor section were poison. The only problem with a mechanical Cat is they are NOT idiot proof even with factory fuel settings, and that only got worse if they were fuelled up.
    Trucknlyfe and Pup97 Thank this.
  8. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    3406B Fuel mileage was good and in the 5 years I never had a issue with the engine. Easy to service.
    Trucknlyfe, Pup97 and Lepton1 Thank this.
  9. AModelCat
    154,240
    You must not get out much if you don't hear anything good about the 3406's.
  10. mudflap77
    mudflap77 Heavy Load Member
    863
    1,313
    Oct 11, 2010
    South western Ontario
    C-13 is a great little motor if you can find someone that knows what to do with the acert part
    gerardo1961 and Trucknlyfe Thank this.
  11. Trucknlyfe
    46
    Nov 12, 2017
    Lol
