Best Car Carrier antenna setup?
Discussion in 'CB Radio Forum' started by BigBob410, Oct 25, 2017.
  1. BigBob410
    BigBob410 Road Train Member
    5,665
    74,100
    Feb 2, 2016
    Beirut on the Bay, MD.
    Now that I'm back out on the road and not runnin' local I miss my cb. I have a Connex 3300 hp zx and am trying to figure out the best antenna and suggestions for mounting it on a Pete car carrier. Thanks in advance for suggestions.
  3. craig_sez
    craig_sez Road Train Member
    5,564
    2,709
    Sep 5, 2013
    novascotia,Canada
    Wow..You got problems.....Anything you can do to get a top loaded antenna(coil at the top,not a predator 10k,k40,wilson 2000 type at its highest point with your connection(feed point) at the same place as your mounting point(ground point/counterpoise,meaning metal mass UNDER YOUR ANTENNA) should go a long ways..
    BigBob410 Thanks this.
  4. Dirtymartini15x
    Dirtymartini15x Light Load Member
    180
    114
    Oct 18, 2016
    Get a regular steel mirror mount and just use the side that has the mount for the antenna, have a shop weld it on the front left of your overhead rail on a 45 degree angle. Works great with just about any antenna you want to put up there.
