Best brand inverter to buy
Discussion in 'Questions From New Drivers' started by Jerms513, Jul 30, 2017.
  1. Jerms513
    Jerms513 Light Load Member
    51
    12
    May 4, 2017
    Looking to buy a 2500 watt inverter...any suggestions guys?! Cobra, best tek, power bright.......
  3. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    From what I have heard none of the inverters sold in truck stops are any good. Something about them having the wrong sine wave. You need to get one at an RV shop and get it professionally installed.
  4. Coover
    Coover Road Train Member
    1,573
    3,593
    Dec 9, 2016
    I had an older xantrex x power 3000 I used daily for 4 years until 2 years ago. The thing is built like a tank and still works, but new truck has inverter built in.
  5. Bigrayon
    Bigrayon Road Train Member
    1,283
    646
    Aug 16, 2015
    You have to get the big gauge wire and the yellow one in the truck stop 3000 watt works don't use more than 1 thing at a time are you will be calling fire rescue to put out your fire
  6. CJndaTruck
    CJndaTruck Road Train Member
    3,348
    3,364
    Nov 21, 2014
    Knoxville, TN (area)
    Xantrex is probably the best true sine wave out there. Worth the $$$.
  7. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,755
    Sep 20, 2014
    I believe most factory installed inverters are xanatrex, fwiw.
  8. CJndaTruck
    3,348
    3,364
    Nov 21, 2014
    Most are but are not true sine wave. Heck the inverter that comes with a tri pak is too but it's not true sine either.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
  10. Michael H
    Michael H Medium Load Member
    466
    1,023
    Nov 3, 2015
    Arizona
    Amazon has two brands of pure sine inverters. I use the AIMS brand. Inverter, charger and pass through 110v. Heavy, but worth it.
  11. Ridgeline
    22,101
    113,192
