Best APU or idle w extra maintenance
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Dagwood007, Dec 18, 2019.
  1. Dagwood007
    Dagwood007 Bobtail Member
    6
    Dec 18, 2019
    Any experiences with APU or less hassle overall to just idle and budget for the extra maintenance? Unit will be a 2020 GMC 3500. Over 25 yrs in trucking, downsizing to a hot shot with a 40ft PJ gooseneck with air ride. Thoughts on air ride on hot shot,welcomed; trolls tolerated. Regards and thanks.
    Chinatown Thanks this.
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,079
    Sep 24, 2019
    Raleigh, NC
    A bunk heater might be worth it, a full blown APU.. not so much.
    An option to consider is a small generator you can mount in the bed and in the summer months use a window a/c unit.
    Lite bug Thanks this.
  4. Chinatown
    Chinatown Road Train Member
    73,251
    164,556
    Aug 28, 2011
    Henderson, NV & Orient
    Maybe an RV dealership can spec it right for your hotshot truck.
  5. rccarlson22
    rccarlson22 Medium Load Member
    431
    761
    Aug 27, 2019
    Avoid idling as much as possible. The new emissions trucks don’t idle without clogging the engine and exhaust. No matter how hard you regen it that soot and Carbon finds a crevice to build up and harden in. I’ve seen 2018’s with less than 25k miles and the EGR and cooler are completely clogged from all the nights they spend idling.
  6. crocky
    crocky Road Train Member
    1,732
    1,577
    Jun 28, 2017
    They don't make a small enough APU for a pickup truck so you will be stuck with battery power and or a generator. You can get Chinese knock offs of the Diesel heaters off Amazon for under $200. They have a lot of positive reviews on youtube and so forth where people have tested them.
    As far as AC unless you figure out some way to rig up window unit or something similar with a generator you will be out of luck. There are companies experimenting with portable AC units that are 12v but they are no where near good enough just yet.
    Some of those purpose built Hotshot cab/chassis with the sleepers use Onan generators and RV AC units but that's also a pricey way to go and gonna be hard to make that work on a normal pick up cab.
    D.Tibbitt and Dagwood007 Thank this.
  7. Lite bug
    Lite bug Road Train Member
    1,391
    28,682
    May 3, 2014
    Columbus Ohio
    Had small generator in the bed for years. Air conditioning in the summer and small heater in the winter. I also could plug the truck in at night, avoid the cold start as much as possible. I wish I had a bunk heater that would have been great.
    Dagwood007 Thanks this.
  8. Dagwood007
    6
    Dec 18, 2019
    I agree and thanks for insight. Did include hi idle switch when ordering. Helps somewhat with that. Regards.
  9. Lite bug
    1,391
    28,682
    May 3, 2014
    Columbus Ohio
    Unless you have a market for the air ride you ROI could take a time. I see it as a requirement and they do pay more however they are few and far between.
  10. rccarlson22
    431
    761
    Aug 27, 2019
    You’ll be fine as long as it doesn’t idle for 30+mins at a time. I get this probably a few times a month, then the customer wants us to warranty $5000+ in parts and labor, that would be ok if you didn’t have 150 idle hours, dingus.
  11. crocky
    1,732
    1,577
    Jun 28, 2017
    They are wanting to idle it over night for heat/AC while sleeping. It will be idling for hours..
