Howes? Diesel 911? Power Service? Lucas? Ect. What's your take and experience with making sure your fuel doesn't gel? I try not to use any unless it's below 20degrees and really windy. My company supplys is with Howes but haven't had to use any yet this year. Fire away!
Best Anti Gel Suggestions?
Discussion in 'Experienced Truckers' Advice' started by Blanche, Jan 14, 2013.
Page 1 of 6
I use powerservice and never had a problem.
For super cold times a little gas works best. Gallon or 2 mixed in a full tank of diesel. -
If your local in Cali I wouldn't worry too much about it. Just carry some 911 if it comes to that. I had my whole tanks freeze up in -30. A half hour and it was going with 911
I've used rubbing alcohol in the past and it worked pretty well.
I always keep a few bottles with me for cleaning. -
I ran in -27 with power service all across Tn. one time, passing boo-coo trucks stalled out on I-40.
be careful with gas if you use to much could score a piston, or it could turn to fumes because of high flow, and when you open your tank if u are smoking. however if you are a vet the government will give you a free head stone. as for rubbing alcohol look at the water content in it.just stick with the popular brands of anti gel and you will b fine.
Tonythetruckerdude Thanks this. -
Page 1 of 6
