Bent rods on a 6NZ....
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JCMtrans, Jan 4, 2023.
  1. JCMtrans
    JCMtrans Bobtail Member
    45
    27
    Dec 29, 2016
    Working on a 6NZ, blew head gasket on #5, which is the only cylinder that had never been cut and shimmed, even though Cat's overhaul paperwork from 300k ago says they only had to cut 1 counterbore because all 6 had been cut in the past and were 'in spec.' Was not a badly blown gasket yet, had to get it pretty warm before it would blow lots of bubbles. 5 and 6 piston/liners are scored. Anyway, tore down engine, took rods to machine shop to have them checked before using IPD kit, and they say 3 are fine, below what they say the limit of 3 thousandths, one is at 3 thousandths, one is at 10 thousandths, and one is bent 50 thousandths. Has anyone ran into this? Can scoring bend rods like this? Do I have no choice but to yank this entire engine, have the block line bored and put a new crank in it? Is there a chance the crank is fine? No damage to rod bearings, very little wear. Wrist pin bushings still have factory machining marks with hardly any visible wear on them as well. Wouldn't 50 thou damage something??
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Silly question.
    If the rods are bent, why don’t you just put CAT cylinder packs in it? Does the crank inspect OK? Have you rolled the mains in yet?
    Oxbow, pup and JCMtrans Thank this.
  4. W923
    W923 Road Train Member
    1,301
    3,965
    Feb 28, 2022
    Did the rod get bent from a hydro lock situation? That’s also a reasonable explanation for a blown head gasket. I highly doubt that scouring the liners bent the rods. I would think the crank is ok. Look it over and mic it.
    Roger McG and bjytech Thank this.
