Benson flatbed trailer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TURKER, Jan 14, 2010.
  1. TURKER
    TURKER Medium Load Member
    344
    97
    Aug 11, 2009
    Raleigh NC
    Hi,
    Can some one tell the weight and the pay load of the 2000 Benson 48'x102" aluminum trailer? Thanks
  3. lowbudget
    lowbudget Medium Load Member
    428
    110
    Apr 12, 2008
    Bismarck, ND
    Call Benson? 877.489.9020.
  4. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Benson closed down a year or so ago.
    The 2000 is the small beam trailer correct? I'm pretty sure it is. I don't know what your going to haul with it, but if it is the smaller beam you might want to look at another trailer. Them weren't the best build trailers.
    TURKER Thanks this.
  5. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    The original Benson closed but were bought by Wabash. The bottom of their website says "A product of Transcraft Corporation" which says enough for me. If it's a "524" it's rated for 52,000# in 4'. The "724" is rated for 72,000# in 4'. If it doesn't have the big number sticker on the frame it's the lighter of the two.
    I had one and used it for lumber. It was ok I wouldn't buy another just because it was pretty weak. Not an issue for most but mine had a Conestoga tarping system and a 48k pound load of lumber would completely take the arch out of it which made the tarp loose which caused a lot of maintenance problems. If it was cheap and your not hauling steel coils it's on par with a East Beast for strength. But like Les said, they weren't the best built trailers. But if given a choice between a steel or combo trailer like a Transcraft or a Benson, I'd take the Benson hands down.
    Here's the one I had. Trailer weighed about 10k with the box, bulkhead, 13 winch straps and all alum wheels, 12,200 with the Conestoga
    TURKER Thanks this.
  6. Les2
    5,150
    2,288
    Jul 25, 2008
    Sorry but I've seen to many Bensons (524 724 and older) that looked like they was gonna snap right at the dolleys, I'd take a Transcraft, if it was an older model in good shape. Well, ok maybe not!:biggrin_2559:. Although I do like the way they built the Valley Transportation Bensons, if they'd just built the rest of their trailers that way they'd have a good trailer!
  7. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    That's exactly where ours would sag, sad really. But unlike the 3 transcrafts I tried it never cracked. Perfect Styrofoam trailers!:biggrin_2559:
  8. Les2
    5,150
    2,288
    Jul 25, 2008
    The biggest problem with Transcraft is people adding extra support to them to stop the swaying. I hauled nothing but coils with mine and the heaviest single was a 55k and all it did was level the trailer out. I was actually impressed with the fact the trailer was a 94 and when I bought it, it was 10 yrs old.
  9. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I have a 94' 48' by 96" all steel trans, my first & only trailer so far.it has done a great job. I haul 45 50,000 lb single coils. every day. I did not like the benson's based on what I saw & the owners have told me. I have been shown by owners how just where the trailer is bolted to the frame, at, around or near the air bags, how it would break & have to get reinforced. the prob was it was harder to get some one who could weld aluminum rather than the steel trailers. I would buy a used retinour before a new benson. I scratched my head at the 4 little bolts that held the bed to the frame on the benson. just looked like they could break off in a tight turn with a lot of weight.
  10. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    bensons are known for cracking where the suspension bolts to the frame in the bolt holes
  11. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    So are the older East's, I have one that was just repaired. The large plates that connect the frame rails above each axle from top to bottom. While it was in the shop they also plated the outside of the frame and replaced the kingpin plate (thanks Michigan for the salt). I've seen a lot of them done this way. 2 of the 3 transcrafts I had ended up cracking the frame just in front of the axles hauling only lumber. I sold the last before it had a chance. Ended up replacing them with 965 Wilsons which are twice the trailer for only about 4k more money.
    hazzmatt89 Thanks this.
