Bendix AD-IS Air dryer problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Keepontrucking2016, Sep 10, 2021.
  1. Keepontrucking2016
    Keepontrucking2016 Light Load Member
    170
    40
    Apr 7, 2016
    I don’t understand this is my 3 air dryer I replaced new compressor new discharge line all new fittings new air dryer new fan clutch cyl new gov builds air just fine no water or oil in the tanks no air loss but every time it purge air comes out from purge valve I can hear it turn off truck no air leak turn truck back on no leak from purge until cutoff why would it do that I need help please
  3. Rideandrepair
    17,197
    55,775
    Aug 8, 2015
    It keeps leaking from purge valve? Is the new govenor adjusted to correct cut out?
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    ADIS dryer is equipped with a preset, non-adjustable governor.
    OP, make sure you have the correct part number governor, you cannot swap the governor with just any aftermarket one. I would start with truck model and verifying parts are correct for the application. Is the governor mounted on the dryer?
    spsauerland, Rideandrepair and Flint1 Thank this.
  5. Keepontrucking2016
    170
    40
    Apr 7, 2016
    It’s none adjustable
  6. Keepontrucking2016
    170
    40
    Apr 7, 2016
    It’s on the dryer and it’s preset to 130psi I’m wondering if I should buy the adjustable one and set it 120Psi and yes I used vin to buy at fl dl
  7. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    No do not replace with adjustable. It will worsen your condition.
    Call Bendix tech line 1800 AIR Brake
    Some ADIS are extended purge and continue to drain after purge. Could this be the issue?
    spsauerland, Ross_Tech and xsetra Thank this.
  8. Keepontrucking2016
    170
    40
    Apr 7, 2016
    What’s weird is I hear it then once in a while I don’t hear it but you can feel all the time
    Dantow Thanks this.
  9. Dantow
    Dantow Bobtail Member
    did you solve your issue I am having same problem 3 air dryers later
