Bend mud flap bracket
Discussion in 'Experienced Truckers' Advice' started by 4noReason, Apr 17, 2017.
  1. 4noReason
    4noReason Road Train Member
    2,375
    731
    Nov 29, 2012
    Anyone have an idea on how to bend a mud flap bracket back to normal.
  3. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    Tractor or trailer?
    I've used a rope and icu bumper or a stationery object. becarefull.
    a hammer
  4. Inthedark
    Inthedark Light Load Member
    98
    91
    Jul 12, 2016
    springfield MO
    Pinch point bar
    dca Thanks this.
  5. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    Hammer if its too bent youll need to get a new bar or maybe your terminal can take a bar off one of their old trks.Maybe have another driver help bend it back in place.
  6. dca
    6,834
    11,427
    May 31, 2011
    Earth
    Picked up a trailer or two with a mud flap bent into a tire . the 2x4x8's laying around broke.. may have been a cheap grade.
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    One of those ratchet straps you can use if you have e track. Wrap around what you want to pull back. Wrap around ICC bar or landing gear...something sturdy. Force it to go where you want it to so you can carry on to a place you can have it properly repaired.
    DDlighttruck and dca Thank this.
  8. dca
    6,834
    11,427
    May 31, 2011
    Earth
    use of the tractor for tension works as long as you don't go to far.
    tonyjxn Thanks this.
  9. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    I was more thinking use the ratchet strap to bend it then remove strap. If the metal can be bent by hand and stay where you need it you are either one bmfd or the metal is not very thick.
  10. dca
    6,834
    11,427
    May 31, 2011
    Earth
    well I haven't had any that bend that easy. but they might
  11. dca
    6,834
    11,427
    May 31, 2011
    Earth
    a come-along
    bluerider and AModelCat Thank this.
