Belt squeal
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Josiah Harder, Jul 7, 2023.
  1. Josiah Harder
    Josiah Harder Light Load Member
    120
    73
    Sep 23, 2022
    My Cummins X15 has had an issue for awhile now where if it sits for over a day the belts will be squealing horribly when I start it up again. Usually the squeal goes away within an hour of driving but man is it loud and embarrassing in the meantime. I'm at home now and it's squealing worse than before it seems and I wanna get it sorted out before I leave again. I tried cleaning them by spraying water while it's running and as soon as the water hits the belt the squealing stops but when it dries up it comes back again so maybe that's a clue. The belt looks to be in good shape.
  3. JB7
    JB7 Medium Load Member
    643
    894
    Dec 13, 2022
    Laurel, MD
    Most likely the tensioner. Some manufacturers sell a small plastic gauge to check the grooves on the belt. The belt can wear but not have cracks. Best to replace belt and tensioner and the squealing should go away.
    Rideandrepair and Josiah Harder Thank this.
  4. Josiah Harder
    120
    73
    Sep 23, 2022
    The tensioner is hopping slightly it's not perfectly still I'm not sure if that's normal or not. It's not jumping wildly but it is moving a bit
    Rideandrepair Thanks this.
  5. JB7
    643
    894
    Dec 13, 2022
    Laurel, MD
    The tensioner is not only for tension but also has a damper in it. If it gets really bad it can ruin the bearings of everything the belt runs such as alternator, ac compressor, water pump. Not a very complicated job. There are videos on you tube. If you decide to do it yourself make sure to check and clean out the pulley grooves.
  6. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Coolant can soak into the rubber if there are leaks or has been leaks or accidental spillage on them. Do not use over the counter belt dressings.
    You can clean all the pulleys with soap and water and thoroughly dry them and just replace the belts with new ones.
    If they are still in good shape and you don’t want to replace them. Try applying a small amount of silicone based grease. Brake caliper grease works good. A little goes a long way. I just smear a glob on an inch or 2 of each belt and then run the engine.
    Best method of cure for belt noise I have found. Course this is assuming belts and tensioners are in good operating condition.
    Do not use petroleum based grease.
  7. Inderjit
    Inderjit Heavy Load Member
    716
    703
    Sep 17, 2017
    The pulleys wear over time and no longer fit a new belt. The alternator pulley
    wears the worst because its the smallest.
  8. JB7
    643
    894
    Dec 13, 2022
    Laurel, MD
    from the Gates website (one manufacturer of belts and tensioners). I basically stated this in post 2 and 4.
    Our research has shown two main causes of belt noise:
    1. Loss of tension in the drive: This is typically indicated by a squealing belt at engine startup. The belt squeals because there is improper tension in the belt drive system. This is usually caused by a worn automatic tensioner, but other causes can include a contaminated belt (oil, belt dressing, etc.) or a belt that is too long or worn out.
    2. Misalignment: A chirping belt typically indicates an alignment problem
    The two primary roles of the automatic belt tensioner are to: 1) apply the correct amount of tension to the serpentine belt as it transfers torque from the crankshaft to the system accessories and 2) smooth out crankshaft vibration associated with the transfer of power.
    A tensioner is a relatively inexpensive part to replace and can help protect other components, such as the water pump, alternator, and A/C compressor, from undue stress and premature failure.
    While the engine is running with the air conditioning on, check the tensioner arm for excessive vibration. If the tensioner arm vibration can be seen with the naked eye, then the vehicle needs a new tensioner.
    Josiah Harder and Rideandrepair Thank this.
  9. Rideandrepair
    17,197
    55,775
    Aug 8, 2015
    Based on all the excellent answers, I would buy a new tensioner. As usual, I would keep the old working one for a spare. Good for an emergency if bearing fails on new one, or diagnostics if bearing starts making noise. Till then, you can get a paper bag, cut 2 holes in it, and wear it over your head till the squeaking stops. Lol
    Soltaker, JoeyJunk and Josiah Harder Thank this.
  10. Josiah Harder
    120
    73
    Sep 23, 2022
    Thanks for the help guys I'm gonna replace the tensioner
    JoeyJunk, JB7 and Rideandrepair Thank this.
